Transmission Temperature Gauge
Old Nov 10, 2005
CivicSF's Avatar
CivicSF should not be trustedCivicSF should not be trusted
Do 7th gen civic have a connection for a digital tranny temp guage? or do i need to buy a mechanical guage instead....
Old Nov 10, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Either way you're gonna have to tap a fitting in there. You can use an electronic one. Just get an oil temp gauge, but its not like there's a hole just sitting there waiting for you to stick a sensor plug in it.
Old Nov 10, 2005
CivicSF's Avatar
shitty
but necessary cause i'm stompin 24/7 on auto
if i do it right i won't need to crack open the housing to remove the drill fillaments
Old Nov 10, 2005
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
Uhm why not just drive normal....Even if you have a temp guage it'll do nothing for protection....Your better off getting a tranny cooler then a guage....Or like I said drive normal.
Old Nov 10, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
yea, i'd get a tranny cooler and then tap a gauge into the coolant line
Old Nov 11, 2005
CivicSF's Avatar
love how people just are like, in similie, "why don't you like vanilla? are you retarded? everyone else like vanilla. why do you like strawberry? just get used to vanilla and forget strawberry. strawberry is stupid."
i'm smackin this throttle 100% all the time. got a tsx front end waiting to go in. steppin on a motor/tranny you know you're gonna replace is one of the most fun things to do in life. even with my race bikes i'm aware of how i'm abusing the components, but with a stock gokart (aka Civic) i'm slidin around every turn possible waiting for **** to fall off
jokes aside, a tranny temp guage has saved my *** previously in two cars, which were both bigger displacement motors, but i woulda ended up blowin seals and maybe stickin gears together if i hadn't know my tranny needed to cool down for a bit before more full thottling on I5 during the a few trips to SoCal. at about 110 for an hour and a half straight you'll probably need some additonal cooling for that small-bearing civic tranny
tapping into the coolant line sounds like a workaround... i'll check it out
cukaracha
30
Jul 26, 2015 12:01 PM
cizsak
Jul 21, 2015 03:39 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
Kyles24
Jul 12, 2015 09:15 PM
silentz
Jul 9, 2015 08:16 PM
