stripped nut
Old Nov 10, 2005
SimplePinoy's Avatar
SimplePinoy is an unknown quantity at this point
stripped nut
As I was attempting to install my new header, I stripped the nut that is on the far right as you are looking at the header. The one that is kinda hard to get to. Any ideas or suggestions on how to get the darn thing off? Please help!!
Old Nov 11, 2005
Michalo187's Avatar
Abortion Survivor
Take off the p/s pump and you can get to it easy. It can try a lot of things and how did you strip it by tightening or losening? You were probably using the wrong socket its a 12 mm is that what you used?
Old Nov 11, 2005
I'd rather not go through the trouble of taking anything off. I did use a 12mm socket, i guess i was just at a wrong angle or something but it stripped. And my dumb*ss didn't stop before it was too late. The nut is pretty round now. Oh, btw, I was trying to loosen the nut to put in a new header.
Old Nov 11, 2005
Michalo187's Avatar
Abortion Survivor
Well just take it to a mechanic and he will get it off for you. Just tell him your new to mechanics and you messed up. You most likely did have it in the wrong angle its a pretty tuff one for a beginner. Good luck
Old Nov 12, 2005
I went to sears and got craftsman bolt-out damaged bolt/nut remover, http://www.sears.com/sr/javasr/produ...%26+Diesworked like a charm. Awesome product. I just need to get a new nut now. thanks for your guys' comments.
Old Nov 12, 2005
PrecisnTec's Avatar
PC Tech / Autocrosser
PrecisnTec will become famous soon enoughPrecisnTec will become famous soon enough
Yeah, those things work great so long as you can get to the damaged nut. If you are trying to get on the back side of a WRX's down pipe with one, then you're screwed.
Old Nov 12, 2005
Michalo187's Avatar
Abortion Survivor
Dam that actually works i had never heard of it maybe i will need to invest in one since my mechanic fvcked up one of my power steering bolts to the tensioner and now its very difficult to get the belt off. How much was it i can't find the price
Old Nov 14, 2005
mrDFWmechanic's Avatar
that cratsman bolt out kit was one of my first tools that i bought and man i've used it soo many times its a life saver it should be a must have for any local garage mechanic
Raiool
Oct 1, 2015 10:42 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
Hollywoodsnake
Sep 20, 2015 12:58 PM
stank
Sep 16, 2015 07:40 AM
