ebay fogs stopped working
Bone Stock!
I had my 01-03 ebay fogs installed back in April. Everything was working fine until last week when it suddenly stopped working. The indicator light on the button still works, and its now brighter than before. I checked the fog fuse and it was ok. There was this red wire coming out from the switch and the copper core was kinda exposed at one point. Could this cause the fog lights to not come on? Or could it be something else? How about that power relay thing? Thanks.
Bone Stock!
Originally Posted by MajinB
open wire. thats all. start cracking open the setup and see if you can find it
Drunken Master-7thgen Ninja
Originally Posted by dalaw
You mean to dig up all the wirings? I am not sure if i can do that cuz i didnt do the install myself.
Originally Posted by Shroomster
here is the answer...EBAY fogs=crap...muahahaha
Honda OEM fogs= 300 dollars
ebay OEM style fogs 30 dollars shipped!
Honda Installation charge=200 dollars
any shop install charge 50-70 bucks.
saving about 400 bucks- priceless...wait its worth 400 bucks!
All this talk about the wiring, etc etc ... Have you checked that the bulbs are still actually working???
I need TP for my bunghole
Bone Stock!
Originally Posted by Notorious SI-G
Check the ground wire for the fog light harness under the hood. That's why mine stopped working. Soldered it to a good ground that won't corrode and all has been good since.
There is only one ground for both lights. You'll just have to follow the harness and see where the ground lug is bolted to the car. Most likely corroded. There is another ground lug inside the car where the harness plugs into the fuse panel.
turn them on & wiggle the plug to the bulb itself & see if it turns on. if it does leave ti that way & tape the wire to the harness liek that. it happened to my driverside foglight & i jsut taped the wire into the connector better & it works fine now.
crowtoo
May 11, 2015 06:50 PM
ORskier
May 3, 2015 12:54 PM
ashleymmackey
Apr 18, 2015 09:48 PM
