Vafc-2 questions... not again right?
Old Nov 2, 2005
phod7's Avatar
phod7 is an unknown quantity at this point
i'll try to make it short. i know i dont have a civic (i have a 2000 accord V6 coupe for ref.) but i have the same problem as many users where the engine bogs (fuel cutoff?) @ ~3500 rpms. i dont have any mods except a SRI from Discount Auto (quit laughing) and my new V-AFC 2. If I turn the car on and floor it (in drive) everything works fine; it only does it when I slowly build up to 3500... any suggestions?
Old Nov 2, 2005
do you have the VTM wire connected?
Old Nov 2, 2005
phod7's Avatar
the wiring diagram doesnt list a vtm wire for my ecu...
Old Nov 2, 2005
but if your car has vtec, then that wire must be connected or the engine light will come on. seems like they messed up the accord too. the tdc and vtm wires were not listed for our civics, yet without them connected, the car will throw a code. If you don't have vtec, then you shouldn't have bought the vafcII. there is an safcII for non-vtec cars.
Old Nov 2, 2005
phod7's Avatar
Unhappy
so i have lt blue, orange, and a blue wire left to hook up? how do i figure out which ones the vtm wire...
Old Nov 2, 2005
doesn't the apexi manual say? then you can ask to look at the electrical manual or something at honda to find which wire it is on the ecu.
Old Nov 2, 2005
apexi says the blue wire is the vtm wire coming from the vafcII
Old Nov 2, 2005
phod7's Avatar
i meant which one is the vtm wire on the ecu
Old Nov 2, 2005
that i don't know. you gotta check the electrical service manual. like i said the dealer is usually nice about letting you look at it for a bit at the desk.
Old Nov 5, 2005
phod7's Avatar
Thanks, I went to the dearship my dad works @ and asked for an electronic service manual and they let me look at it for as long as I wanted. I found out Accords DO have a VTM wire just like civics and with it hooked up the V-AFC 2 works just fine. One problem solved, now where the hell can I find a dyno tuning shop around here...
Old Nov 5, 2005
glad it worked out
Old Nov 7, 2005
ohnoitssoysauce's Avatar
ohnoitssoysauce is an unknown quantity at this point
what does the safcII do?
Old Nov 7, 2005
same as vafcII but without the vtec control. just fuel curves and engine monitoring.
Old Nov 7, 2005
so it's not really worth getting right?
Old Nov 7, 2005
i'm selling mine cause with I/H/E pnp cam gear i didn't even need it. the ecu does a pretty good job adjusting closed loop fuel below wot +/- 20%. only thing the controler is good for tuning is wot a/f and even then it doesn't do much.
nighthawk1903
Feb 19, 2006 02:16 AM
ncirom2003
Engine Swaps
32
Sep 19, 2005 05:44 PM
ncirom2003
Sep 6, 2005 06:13 AM
Cocky
Aug 10, 2005 03:31 PM
SpacemanBob
Jul 7, 2004 05:18 PM
