sneak peak of my new setup.....
Old Oct 23, 2005
turboengnr's Avatar
DONT PANIC
Heres a sneak peak of what i finished tonight.
Not too bad for a days work. It will go on the car tomorrow.
When i found out that the last several parts for my custom one i was making would cost me over $100, i got pissed off and said "screw it".
So i went to hang out over at my buddies storefront, and he had a GSR intake manifold sitting there. So i asked him "how much do you want for that manifold?" And he said "$30". I told him, "im too poor, i cant afford that" so he said "fine, get me a strawberry cream frappuccino, and we will call it even"
So i brought him his frappuccino, took the manifold and ran.
My wife works at starbucks, so it didnt cost me a thing!!
Old Oct 23, 2005
Ashhole's Avatar
Ashho-san 7thgen Ninja
Ashhole will become famous soon enoughAshhole will become famous soon enough
lucky bastard. how well does it line up? any major modifications to it?
Old Oct 23, 2005
Michalo187's Avatar
Abortion Survivor
that looks pretty dam good. You are very lucky. You did all the work yourselve? I wonder how much its going to help you out
Old Oct 23, 2005
Ashhole's Avatar
the whole thing is gonna have a lot more flow than those plastic things they put on our cars. plus he'll be able to enlarge the TB and get more flow that way also.
on a side note, have they made a larger TB for our cars? or are we still just porting out the old one?
Old Oct 23, 2005
andyman97's Avatar
Turbo Guru
Cool man. Have you checked for fitment? Looks like the runners are a bit longer than the d16 so I'm curious if you'll be able to get it in. Also, why use a 7th gen fuel rail? Planning on just using k series aftermarket injectors on it? Smart move on putting on the d17 tb for all your sensors. Good luck, hope it works out for ya.
Old Oct 23, 2005
turboengnr's Avatar
DONT PANIC
Thanks andy and everyone else.
I did do all the work on it. On a normal day, i would have had this thing done in a matter of 2-3 hours. But since my shoulder is screwed up, it took about 8 hours. I did this at my dads house so he could help out.
We ended up cutting the manifold in 2 lengths, and then welding it back together to get the runners where we needed them. We then ported the manifold back smooth on the inside. Then we welded the runners to the stock injector plate, and ported them out to match.
I used JB weld inside the runners in order to make sure everything sealed. in the morning i will port it all back smooth again. I couldnt get inside there with my TIG because i dont have a small torch. My machine isnt water cooled, so i am stuck with the large head.
We then made an adaptor plate for the TB, and welded it onto the manifold. And screwed the stock manifold on. I am going to tap the holes where the GSR IAC was and screw in a fitting to draw manifold pressure from.
The only mods i had to do to the fuel rail was cut off the tube for the EVAP (i will route it different later on) and take off the EVAP port (the black thing on the fuel rail)
I will be using my SRT stage 3 injectors. They are already wired up and they fit, but i wont install them until i am done with the turbo system and my new motor.
Later on, i am going to get an RPM service 76 or 80 mm TB for the GSR and use it. I will do that sometime after i find a GSR IAC (they are hard to come by out here). And i know the owner of RPM service, so i can get one of those anytime.
Old Oct 23, 2005
turboengnr's Avatar
DONT PANIC
i forgot to mention, the way i did this manifold, it is only about 1/2" longer than the stock manifold. So it comes a tiny bit closer to the firewall, but i still have about 4" of clearance.
I havent had it on the car yet. So tomorrow may bring some nasty suprises.
Also, I am wiring the secondary butterflies to my vtec solenoid. So when vtec engages, the secondary runners will open. I am hoping for a hell of a kick when vtec engages. Maybe i will actually be able to hear the vtec engage!
Old Oct 23, 2005
Michalo187's Avatar
Abortion Survivor
So srt 4 injectors actually do work for our cars? You need the clips right? will they fit with a kms im on the car or will it hit the tps?
Old Oct 23, 2005
turboengnr's Avatar
DONT PANIC
I know that the SRT injectors fit the stock manifold.
I posted pics a while back at the request of dezod. They are the same dimentions of the RSX injectors, except for the fact that mine flow a hell of a lot more.
You only need the injector pig-tails off the SRT wiring harness.
Old Oct 23, 2005
mugenman's Avatar
"mmmBAHHHH" - vtec y0
looks good man let us know how it turns out
Old Oct 23, 2005
turboengnr's Avatar
DONT PANIC
i will let you all know tomorrow.
Also, im going to be in a movie tomorrow! Well, im not, but my car is going to be. Its a DVD only release of a movie that is about skateboarding and the underground music scene.
Old Oct 23, 2005
Michalo187's Avatar
Abortion Survivor
Good luck! So where can i find these srt-4 injectors? What size cc would i need to one day try to get 300whp?
Old Oct 23, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
nice!
did you do anything with the butterfly valve?
Old Oct 23, 2005
iamboo's Avatar
Retired - SoCal FI Mod
Originally Posted by aznboysrfr
nice!
i'm not sure if our ECU's will open up the secondary runners because it's not a OBD1 like the GSR's.... he could completely remove the vacuum line that goes to the valve and it'll keep it open or for flow reasons, he could completely remove it altogether.... there have been some controversy on this in the past on whether removing the butterfly valve makes more power and IMO, in a FI setting, the car will flow and respond better without it...
Old Oct 23, 2005
ncirom2003's Avatar
and.......subscribing.
as for the secondary runners, they are closed at low rpm to make more torque.
Old Oct 23, 2005
tfnaaf's Avatar
BLDNPSI Mod
nice work, keep us updated!
Old Oct 23, 2005
drew22mader's Avatar
There is gl@ss in my @SS...
He had to go to sleep early last night so he can get it done this morning. Better be worth it, i don't know how he does it with his hurt shoulder.
Old Oct 23, 2005
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
I like your approach.
I'm curious about the fittment.
Can you post pictures when installed?
And I wonder if you have to milled the flange flat since you welded it.
The high heat needed for welding the aluminum/magnesium intake will warp the flange.
Then you'll have all kinds of pressure/vacumm leaks.
It looks very good and I hope it works with your set up.
Old Oct 23, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
If you clamp it down to a thick, flat benchtop and skip around you usually wont warp it as long as it cools down before you unclamp it. I have made quite a few different styles of manifolds and never had one leak, knock on wood. If you have a bunch of gaps in the weld joints at the flange they may try to close up (shrink) as the welds cool, which could create warpage if you are careless. Im sure by the looks of it he is quite experienced though, Thumbs up on the new manifold idea dude, looks cool. Cant wait to see how it looks on the engine.
Old Oct 23, 2005
turboengnr's Avatar
DONT PANIC
actually, if you weld it in a certain pattern it will not warp at all. And thats what i did.
I started it up a few hours ago and it purred like a kitten at 1100 rpm. Once it got warm, it went down to about 750.
I had to orient that throttle body a little differently than in the previous pics, and add a throttle cable bracket. But it all worked awesome!
I have massive wheel hop in 1st gear when vtec engages. I have the solenoid wired up to open the secondary butterfly when the vtec engages.
anyway, heres the pics of it installed.
Lemme warn you, it is a royal B*TCH to get in there. But once it is in place, it clears everything.
Old Oct 23, 2005
tfnaaf's Avatar
BLDNPSI Mod
looks different thats for sure! Nice work...lets see it boosted
Old Oct 23, 2005
HondaLuver's Avatar
Its a celebration bitches!
dam, thats sick, are you still using my oem exhaust? hah
dyno that bitch and stick ur turbo on~!!!
Old Oct 23, 2005
iamboo's Avatar
another great innovation by mike... yay!!! YOU GO MAN!!
Old Oct 23, 2005
Ashhole's Avatar
that looks real cool. gotta put up some numbers for it
Old Oct 23, 2005
02fpcivic's Avatar
sweet, fits nice in there.
Old Oct 24, 2005
turboengnr's Avatar
DONT PANIC
it will be boosted soon enough.
I actually only have the stock head pipe and cat on there. Cat back is 2.5"
Old Oct 24, 2005
blouisgod's Avatar
Life Begins > 6800rpms
damn thats sick! nice work!
Old Oct 24, 2005
acidbaby's Avatar
The Beez Kneez
great move forward to modding the d17
Old Oct 24, 2005
gotti's Avatar
you're the man now dog.
Old Oct 24, 2005
Michalo187's Avatar
Abortion Survivor
dam it looks sweet nice work
