RAZ cams add 30hp untuned !!!!
checkin out the clubrsx.com threads and wow cams add 30hp untuned thats simply amazing. makes me wanna do my K20 swap even more http://forums.clubrsx.com/showthread.php?t=283031
Good #'s
but all new hp's are on top
low and mid hp's are lower then stock.
Also, does stock rsx-s males only 150whp? looks way to low.
I think all #'s a little optimistic.
I saw that,
cant you see the graph?
For the stock run, engine run to about 7700 rpm
With cams the runs were made to about 8200 and 8400 rpms.
Does stock k20 go to 8000?
'Cause I dont think so.
But I might be wrong...
Fromt he signature of the guy with RAZ cams:
Engine/Transmission: Raz Cams, custom intake, coated borla header, custom 3" exhaust, intake manifold gasket, MM inserts, K-pro, type-s clutch/flywheel, 6spd tranny + ep3 final drive
I think all these toys come on this motor from the factory...
Indeed, fully stock engine.
He is saying that his K20 with a custom intake, coated borla header, custom 3" exhaust, intake manifold gasket and Hondata K-pro only made 148 HP. Then he put in a set of cams and magically made +30HP!
I would love to see these cams put in a bone stock, healthy K20 and a real back to back comparison made. I have serious doubts about the validity of this test and the tune of the baseline motor.
But, people will no doubt buy them based on this one test.
same cams, but on the bone stock engone.
hp estimates anyone?
ricer_em2
May 11, 2016 08:09 PM
Munzy
21
Oct 7, 2015 07:48 AM
Islesfan
Sep 29, 2015 03:42 AM
OptimisticWay
Sep 18, 2015 09:37 PM
