Strange vibration noise at 2500 RPMs???
Old Sep 21, 2005
Eightball's Avatar
Eightball will become famous soon enoughEightball will become famous soon enough
Angry Strange vibration noise at 2500 RPMs???
Ok so I don't know exactly where it's coming from. Somewhere under the hood. When I'm driving and hit around 2500 RPM I get a high pitched vibration sound. It doesn't do it if i'm in neutral except at maybe 6-7000 rpms. It keeps doing it as long as I hold it at 2500 RPM. Seems like its slowly getting worse. Since I can't listen for it when it's parked I'm having trouble figuring it out. I can't find anthing wrong when examining the engine and exhaust. Any ideas???
Old Sep 21, 2005
doctor's Avatar
Type-Race
doctor will become famous soon enoughdoctor will become famous soon enough
high pitched? Or is it more like a buzzing? I had that coming from the center console and I replaced 2 of my motor mounts and it went away so check your mounts......
Old Sep 21, 2005
Jrfish007's Avatar
my guess is a heat shield... I've got one vibrrating at about 3k on my GSR.
Take a long stick, shove it under your car and hit the cat, see if it rattles. From the pics in your sig, it looks like you don't have any heat shields around you header.
More questions:
Does it go away in different gears?
Does it go away when the RPM's get highers, if so when does it stop.
If it does stop, does it do suddenly or slowly die away?
Old Sep 21, 2005
my hood used to vibrate cause it was loose. try turning the rubber stoppers so it sits lower and closes more tightly.
Fudman
Suspension
Feb 1, 2020 04:13 PM
Jul 12, 2015 11:54 AM
fvckbg
Jul 7, 2015 07:08 PM
Wild Cranker
May 19, 2015 06:10 PM
Ninetyatecivic
May 9, 2015 07:48 PM
