Rod knock?
Wanna see a donkey show?
It is definatly a spun bearing. Which can be caused by oiling issues or spinning the motor to high for the oil pump to suply oil. I wanna know what you did up to this point too!
Originally Posted by tfnaaf
streched the rod bolts/cap and spun the bearing
Originally Posted by streetglower
I am no expert on this, but please explain why that causes this or how it caused it. Usually I thought that this was caused by not enough clearance in the bearing to crank causing a lack of lubrication.
Just going off what i can see in the pciture it appears that the bearing spun inside the cap. This is usually caused from stress to the rod/bolts causing them to stretch then the bearing spins inside the rod. Its possible there was an oil starvation issue but its a little hard to say for sure
hmmmm, im thinking of possible causes, first thought is detonation trying to push the piston down before tdc and in turn hesitating the crankshaft putting stress on another pistons connecting rod in an opposite direction opening a clearance and spinning the bearing when it closes again. however i dont think this is it lol
Turbos, Engines, Chassis and Suspension Tech
The bearing cap didn't stretch. The bearing is elongated because i had to pry it off the rod journal on the crankshaft. As of now it looks like an oil pump failure is to blame. The engine is a completely stock D17A2 with about 60k miles on it. The bearing did indeed spin inside the rod hence the off-setness of it.
Joecrowe
Sep 24, 2015 09:12 AM
Styven Szastur
Sep 23, 2015 05:26 PM
curaze
Sep 22, 2015 08:27 AM
