Rod knock?
Old Sep 11, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Rod knock?
So who can tell me what happened?
Old Sep 11, 2005
micks7thgen's Avatar
micks7thgen is an unknown quantity at this point
your engine was royally f****d thats what happened
Old Sep 11, 2005
Well that I know.
Can anybody explain WHY this happened?
Old Sep 11, 2005
a little back story would help what were you doing when this occured.
Old Sep 11, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Overheating the bearing, oil starvation.... So what led up to this?
Old Sep 11, 2005
C2i0v0i1C's Avatar
SuperMODrizd
u pulled the bolts out damn!
Old Sep 11, 2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
i just did the same thing on the engine i JUST replaced, i think its some sort of lubrication issue, and btw when i pulled the piston out the rod had no bearing left on it....
Old Sep 11, 2005
tfnaaf's Avatar
BLDNPSI Mod
streched the rod bolts/cap and spun the bearing
Old Sep 11, 2005
cg95660's Avatar
Wanna see a donkey show?
cg95660 is an unknown quantity at this point
It is definatly a spun bearing. Which can be caused by oiling issues or spinning the motor to high for the oil pump to suply oil. I wanna know what you did up to this point too!
Old Sep 11, 2005
streetglower's Avatar
I am no expert on this, but please explain why that causes this or how it caused it. Usually I thought that this was caused by not enough clearance in the bearing to crank causing a lack of lubrication.
Old Sep 11, 2005
ncirom2003's Avatar
spun bearing it seams.
Old Sep 11, 2005
tfnaaf's Avatar
BLDNPSI Mod
Just going off what i can see in the pciture it appears that the bearing spun inside the cap. This is usually caused from stress to the rod/bolts causing them to stretch then the bearing spins inside the rod. Its possible there was an oil starvation issue but its a little hard to say for sure
Old Sep 11, 2005
what usually causes that stress?
Old Sep 11, 2005
ncirom2003's Avatar
hmmmm, im thinking of possible causes, first thought is detonation trying to push the piston down before tdc and in turn hesitating the crankshaft putting stress on another pistons connecting rod in an opposite direction opening a clearance and spinning the bearing when it closes again. however i dont think this is it lol
Old Sep 11, 2005
Rufus's Avatar
HAHA I did the same thing... I need to post pics as well
Old Sep 11, 2005
The bearing cap didn't stretch. The bearing is elongated because i had to pry it off the rod journal on the crankshaft. As of now it looks like an oil pump failure is to blame. The engine is a completely stock D17A2 with about 60k miles on it. The bearing did indeed spin inside the rod hence the off-setness of it.
rovafa2002
Sep 28, 2015 06:57 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
Joecrowe
Sep 24, 2015 09:12 AM
Styven Szastur
Sep 23, 2015 05:26 PM
curaze
Sep 22, 2015 08:27 AM
