open ended or closed
Old Sep 6, 2005
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
don't know if this is better suited for here or techchat
if this has already been listed tell me cuz i typed in the search "open ended filters" but got nothing.
Is there a difference (except for price) between open ended cone filters or closed? or even those 'turbo' filters that look like a shroom with mesh on em?
Old Sep 6, 2005
shroomster's Avatar
bumpity bump
Old Sep 6, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
i'm not certain, better have the tech ppl come in on this...
but on the Civic, and many 4 cylinder engines, a closed end provides enough air already.
Old Sep 6, 2005
shroomster's Avatar
My AEM S.R.I came with a closed end filter but I've seen ppl with the open ended ones and even those stupid plexi glass boxes covering the filter...I doubt that plexi glass disperese heat better than an actual heat guard..or hell if it even allows enough air flow
Old Sep 6, 2005
diskreet's Avatar
plexi is a bad idea. even lucite is useless a little over 100 degrees to thats dumb. as for heavy plexi, still stupid.
on a N/A 4-banger closed is fine. Open is fine. Shroom is fine. depends on actual filter construction. some filters can be almost as good as no filter at all, while others suffocate the engine
Old Sep 6, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Use lexan or polycarbonate if you're going to fab a shield.
Open or closed doesn't matter, it lets in more air than the car needs anyways.
Old Sep 6, 2005
ashtonp's Avatar
ashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to behold
from what i've heard, open ended filters are a bad idea. Apparently they create a vaccuum that can potentially cause damage. I believe this since a guy i knew had one, and the intake sucked in the conic part of the filter.
Old Sep 6, 2005
Jap-Euro Fusion
Without the vacuum, the engine doesn't run. So the vacuum doesn't cause damage. The intake sucked in the end of the filter because it was probably a **** ricer filter that was held together with hot glue rather than something made to do the job right.
There's far too many poorly made, shitty parts that people buy vs shelling out the money to buy one of the few filters worth buying.
Old Sep 6, 2005
ashtonp's Avatar
^^ yea probably, i didn't know the exact details of the situation so i can't really comment on ur thoughts
Old Sep 6, 2005
yup! those autozone filters, or cheap $15-$20 filters can do that. My brother had a generic filter on his car and the hot glue used just didnt cut it.
bluedoggy1
Jun 20, 2015 11:25 PM
siCaddie
Jun 2, 2015 07:35 PM
MamaBear2015
May 3, 2015 02:17 PM
tkcne
Apr 18, 2015 02:33 AM
supercivic01
South
Nov 30, 2001 11:27 AM
