Need help w/code plz
Old Sep 3, 2005
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
Just got my car back. FINNALY!
Turbo boost
Is running good with optos base map on my e- manage.
I got a code check engine light.
I just recently acquired the digimoto system and check the code.
I got p1106 dual alternator lower fault/
I just read the code on the TECH MECHANICAL site sticky post and got
P1106 BARO circuit range/ performance
Just wonder if anyone may have some idea of what that is.
I tried the tech book but didn't found
Any advice will be gratly appriciated.
Old Sep 3, 2005
MiamiUgen7's Avatar
p1106 is the map sensor. it is reading boost. you need to adjust the voltage clamp on the e-manage
Old Sep 3, 2005
andyman97's Avatar
Turbo Guru
If you searched for p1106, you'd find a thread from last october that talks about the baro pressure vs. map pressure and possible causes. I'd start there.
Solo Flow
Oct 4, 2015 07:52 AM
Luluharp
Sep 27, 2015 11:56 AM
jody501
Jul 10, 2015 11:01 AM
Myredjonda
Apr 14, 2015 07:00 PM
PeArlHoNdA
Mar 6, 2002 04:18 PM
