Problems with dropped Civics?
Old Sep 2, 2005
HondCivc91's Avatar
HondCivc91 is an unknown quantity at this point
Hey all - I searched for this already and couldn't find anything in specific, but I lowered my '05 Coupe a few months ago with the Eibach Prokit and SPC Camber kit in the rear, and all I have had since are problems!! The first week everything was in, there were no noises, eveyrthing was perfect. But after the first month, and for the past few months, I've constantly been hearing knocking noises when I go over bumps, metal-against-metal scraping, etc - the list of annoyances goes on.
I've take out the struts and springs since them, and reassembled it again, and that will solve the problem for just a few days - but soon after again all the noises start up. Nothing looks warn, the boots, the bearings - EVERYTHING looks fine. Its getting to the point that I'm tempted to put it back to stock just so it'll solve the problem
My question is, how many people with lowered 7thgens that also have these annoying noises???
Old Sep 2, 2005
blouisgod's Avatar
Life Begins > 6800rpms
is the hardware on the stock strut wrecked / blown? it sounds like the stockers are broke and the internals are rapping against eachother once it settles. ive switched to coilovers and now my problems are with scraping, lol. once you mess with something, be prepared for consequences no matter what it is.
Old Sep 2, 2005
HondCivc91's Avatar
No, I'm pretty sure eveything looks fine - it looks exactly the same as when I put them in. Mostly I've been getting a loud knocking noise when going over bumps, turning the wheels, or just driving straight. It sounds like the CV boots are ripped, but they're not.
Old Sep 2, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
Sounds to me like you're just weren't expecting using the stock struts to give you a problem. Sure they will be noisy. No way around it, other then getting aftermarket shocks.
Old Sep 2, 2005
HondCivc91's Avatar
That's true. I mean I was expecting this to happen eventually .. I just didn't know that it would start happening a month after I put new springs in. Is it typical for the stock struts and shocks to make noises with just lowering springs in?
Old Sep 2, 2005
Maybe I'm not paying attention, but I have the exact setup as you on an 02 sedan and can't really tell the difference.
Old Sep 2, 2005
HondCivc91's Avatar
how many miles have you put on the prokit since you put it in?
Old Sep 2, 2005
flotsamm's Avatar
If theyre not indexed correctly, you can get noises like you describe.
Old Sep 2, 2005
flotsamm's Avatar
This is what it should look like:
You have to make sure that the arrows on the top mount and upper spring perch and lined up with the hole on the bottom perch.
Old Sep 2, 2005
oh hmm we didn't even cheak that when my friends did mine.
Old Sep 2, 2005
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
No **** right! ha ha /\
Old Sep 2, 2005
Blahman240's Avatar
OH SNAP! Those arrows need to be lined up? I never knew that... Never had a problem either. When I do my tie rod end this weekend I'll check on that, it may be difficult, cause I don't have stock struts.
Old Sep 2, 2005
HondCivc91's Avatar
yeah i know about indexing .. before i put my own springs in, i read the DIY on here and also saw that and specifically looked for that when I put the strut assembly back together ... we'll see i guess. Thanks for all your help so far guys.
Old Sep 4, 2005
03civsilv30's Avatar
03civsilv30 is an unknown quantity at this point
same problem
Yea i just installed eibach pro kit last weekend except it started to rain and I only had time to complete both the front installs. Everything was cool right away but a couple of days after i notice the same knocking from the front drivers side. I've check everything and it all looks in place. Thursday night i drove down to the Dolphins game (i know they suck this season) and on the way back the knocking was coming to a climax. Now whenever im not steadily accelerating or braking the knocking is atrocious. Everything looks to be in place and I too followed Mex's installation and lined up the indexing. I will see if there is anything i can do to alleviate this once it freaking stops raining! I have not been driving my car since thats how bad the knocking is.
Old Sep 4, 2005
TeLLy's Avatar
Yes, it's an Acura EL
My car had knocking noises as soon as it was lowered the very first time. The guys at the shop did their best to fix it, in fact they removed the suspension 3 times that day to get it all indexed properly and triple-check all the nuts and bolts. The noises subsided to a tolerable level in about a week. I was pretty much resigned to having a noisy suspension, as Blahman put it you will always sacrifice something when modifying. The noises were still there, especially over bumps and low-speed turns, and my friend and I finally figured out that it was just the springs popping. When I would hit a bump, the spring would compress and due to it being a COIL, the spring assembly turned a slight bit in its perch and then bind, then POP a split-second later as it released back to its original position.
Old Sep 4, 2005
cubanmike26's Avatar
I too have been having popping noises on my suspension as well ever since it got installed almost a year ago. I have Sportlines and Tokicos HPs and the problem seems to happen like you guys said, on any bumps or holes on the street. We check the suspension at the shop a couple of times to make sure everything was fine, well, they didn't find anything wrong...I just got used to the noise after a while...
Old Sep 4, 2005
xDCx's Avatar
xDCx will become famous soon enoughxDCx will become famous soon enough
somebody fix it
Old Sep 4, 2005
pnoiracer's Avatar
pnoiracer is an unknown quantity at this point
same thing happening to me!
Old Sep 5, 2005
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
hmm, never happened to me with my neuspeed sports and tokico d-spec. well i did have a shop install it and the guy who did it knew exactly what he was doing for everything on my car. gave me a good deal too.
Old Sep 5, 2005
DePonce's Avatar
DePonce is an unknown quantity at this point
I have an '04 coupe with newspeed springs and I get a mild knocking sound but is not bad at all.
Old Sep 5, 2005
DDragon7's Avatar
Not sure what shocks or spirngs mine has, since I got the car with the suspension (2" drop), but it also creeks in the back mostly from the right side of the car that I can hear.
Old Sep 5, 2005
slicksivik's Avatar
take a can of wd40 and spray like hell and itll go away after u drive around for 2 minutes. happens to me a lot especially after i wash the car. a WHOLE CAN of wd40 gets rid of it.
Old Sep 5, 2005
xkimsungminx's Avatar
xkimsungminx is an unknown quantity at this point
hmm.. i'm on H&R sports and i haven't had any problems or noises coming out of my car post installation, but i'm not on chamber kit or aftermarket shocks.
Old Sep 5, 2005
04|5spdCivic's Avatar
Wish I had a Turbo 3)
04|5spdCivic can only hope to improve
i have an 04 coupe with progress lowering springs and stock shocks. we did it ourselves and when i turned the wheel at first it made knocking sounds in the front passenger setup. we took it all apart greased all the bearings and greased practically everything, and adjusted the spring a little. when we put it back together i havent had a single problem since. no knocking or anything. damn im good. lol jk
Old Sep 5, 2005
TeLLy's Avatar
You just reminded me of something a friend did on his gf's EP (same problem when he lowered it). He took the front struts out and popped the top off to expose the bearings. He said he sprayed the bearings themselves with WD40 in order to effectively dilute the grease they were already packed in, because he said for some reason it was too thick. Once he indexed and reassembled it was quiet. I can't say I actually saw him do this and no one else has told me about it, but I thought I'd throw it out there in case anyone wants to try. Worst case scenario it doesn't work and you have to slather some more grease in there after.
Old Sep 5, 2005
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
same problem here too at first. took the suspension apart several times, reindexed and everyting. then i noticed a ball bearing wedged behind the spindle. i ended up buying a new strut bearing..the bbs came out somewhere(? never found them all) then lubed everything up with white lithium grease...no probs since..and they've been on about 6 months now...
Old Sep 5, 2005
boricua_civic's Avatar
In love with Diana...te amo
boricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond repute
I have tein springs on my 04 civic and the driving feels even better.
Old Sep 5, 2005
DDragon7's Avatar
Whoa, a whole can of WD40? So where do I spray that?
Old Sep 7, 2005
bhoy's Avatar
bhoy is an unknown quantity at this point
yup it happen to me tooo..i got 5" drop 04 civic. i spray it with WD40 to deff it will work....
Old Sep 7, 2005
matt_s's Avatar
Super JDM Member
matt_s is an unknown quantity at this point
yeah im on progress springs with stock shocks (for now), and i hear a variety of different noises daily. Its quite annoying but im used to it. I hope new shocks will help, or i may even consider getting true coilovers.
