Ok to drive with rear sway endlink broken?
while installing my rsx rear sway, and stripping that 5mm hex key bolt, I can still use the other endlink, my question is, untill I get it replaced, will it be ok to drive around with it being attached to only 1 endlink?
thanks
thanks
but say I use my car just for going from place to place with no hard cornering or driving in mind, Ill be ok hey? Also, is this a good opportunity to buy Greys endlinks, or should I just go to honda and get The oem one? Also, one last question, do I need to torque those endlink bolts or just as tight as I can go?
Thanks
Thanks
It'll make noise, but you won't damage the car.
Theres no reason to buy anything more than the $13 Honda links with an RSX bar. There is a torque spec on the nuts, but with the allen key, you can't get a torque wrench on there. I just go until its tight. If you push too hard, you strip the allen key.
It costs 35 cdn here, which is about 27 usd, if someone wants to buy one for me, Ill gladly paypal you, It wont cost as much then and I can save some money. Ill even pay you before hand
Not on something SO small, put it in a padded envelope and mark gift, Im dead serious too, thats what everyone does that I know and ebay, and never had to pay.
Xuhme
21
Aug 7, 2023 03:40 PM
Rogelio Rey
May 24, 2015 08:30 PM
oneheadlight
Apr 29, 2015 11:30 PM
smmahan
Apr 15, 2015 08:17 PM
