cam gears
The stock cam gear is not adjustable and aftermarket performance ones are. They are usually used with aftermarket cams. They are mainly used for tuning the cam. And usually tuned with a dyno for the best gains.
yup aftermarket are adjustable +/- degrees. It adjusts the cam timing (which also affects ignition timing slightly on our cars). Needs to be dyno tuned. Good when paired with aftermarket cam and/or pnp head thats been milled down. You most likely need to switch gas if you play with that.
nirvanaguy
25
Oct 26, 2017 07:26 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
tommycanada
Sep 5, 2015 04:59 PM
WaryDriver
Aug 16, 2015 11:22 AM
