cam gears
Old Aug 27, 2005
slowwhitecivic's Avatar
slowwhitecivic will become famous soon enough
cam gears
hey guys was just wondering wut does puttin an aftermarket cam gear will do,, wuts the different between the stock one and the for example aem cam gear.
Old Aug 27, 2005
dariusld's Avatar
dariusld is an unknown quantity at this point
The stock cam gear is not adjustable and aftermarket performance ones are. They are usually used with aftermarket cams. They are mainly used for tuning the cam. And usually tuned with a dyno for the best gains.
Old Aug 27, 2005
yup aftermarket are adjustable +/- degrees. It adjusts the cam timing (which also affects ignition timing slightly on our cars). Needs to be dyno tuned. Good when paired with aftermarket cam and/or pnp head thats been milled down. You most likely need to switch gas if you play with that.
nirvanaguy
25
Oct 26, 2017 07:26 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
tommycanada
Sep 5, 2015 04:59 PM
WaryDriver
Aug 16, 2015 11:22 AM
Ccoop87
Jul 9, 2015 03:26 PM
