20k Maintenance
Old Aug 24, 2005
Chulo's Avatar
Chulo is an unknown quantity at this point
20k Maintenance
Hey, just curious at what I'm looking at for my 20k, plus some new brakes. Any proximates? Thanks a lot.
04 ex coupe
Old Aug 24, 2005
streetglower's Avatar
change oil and filter, check and/or replace the air filter, change tranny fluid, check brakes, check all fluids. Its not nothing major.
Old Aug 24, 2005
Jrfish007's Avatar
isn't the tranny fluid suppose to go for 40k on the factory stuff, then 20k every change after that? I forget
Personally I think 20k is kind of quick for a new set of brakes, but I guess if you drive in the city, you might run them down that quick.
Old Aug 24, 2005
if you have an auto, change tranny fluid every 10k.
Old Aug 24, 2005
Jrfish007's Avatar
Ahhh... I see thanks. But does the intial factory fluid stay in for 20k?
Old Jan 6, 2006
Eclectic's Avatar
Eclectic is an unknown quantity at this point
hmm, in the owners manual it also says i need to inspect the suspension components. what should i be looking out for?
i guess my manual is misprinted because it says you replace transmission fluid (manual) at 120k miles. hmm..
oh btw, i'm confused...so there's an air filter and dust/pollen filter under the hood? or are they the same?
Old Jan 6, 2006
stinkypie's Avatar
A big, hairy Kentucky boy
stinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to all
The dust/pollen filter is behind the glovebox.
Old Jan 6, 2006
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
[QUOTE=Eclectic]i guess my manual is misprinted because it says you replace transmission fluid (manual) at 120k miles. hmm..
QUOTE]
no it's not a misprint, that 120 is for those of us who drive on government controlled conditions test tracks at constant rates of speed.
Old Jan 12, 2006
Eclectic's Avatar
ok seriously how do you check the suspension because the scheduled maintenance in the owner's manual says to do so at 20 miles....
Old Jan 13, 2006
nothing to check really. i'm at 40k and no problems. all they do is nothing. if you get a good mechanic they will make sure the bolts and stuff are tight.
SammySC
121
Apr 7, 2017 07:43 PM
WWJD
Sep 23, 2015 12:56 PM
mrdoc
Aug 25, 2015 05:59 PM
