Quick question about coilovers and lowering springs!! plz read thanks :)
Old Aug 24, 2005
tommyhoang_ta's Avatar
tommyhoang_ta is an unknown quantity at this point
Hi everyone
I have a quick question about supspension. I have a 2k1 vic dropped on Ground Control coilovers w/ Tokico blues. However the ride kinda bouncy so i was thinking about swap to lowering springs w/ about the same drop (around 2" all around). My question is will my ride get any better after the swap? If so how much better it will be? And what springs gonna give me about 2" drop? Thanks alot.
Old Aug 24, 2005
pinoyjdmr's Avatar
pinoyjdmr is an unknown quantity at this point
if I were you sell those and get you some D2 damper kit with 36 way dampering and your ride would be all good ............
Old Aug 24, 2005
JCiv03's Avatar
Correct me if I'm wrong, but i think it depends on the spring rates as well as how much the springs lower. I'd probably compare some of the spring rates first...
Old Aug 24, 2005
robbclark1's Avatar
Retired suspension supermod.
Uh, NO. D2s are crap.
It depends. The thing with progressive springs and tokicos are that they will bounce. Tokicos are stiffer than stock but aren't like konis. And progressive springs do bounce. The stiffer the spring, the less the bounce, generally. So in the end, your ride may or may not improve depending on the type of spring.
Old Aug 24, 2005
thanks alot for the answers. So what spring set gonna give me better ride than GC coilovers? ima noob about supspension lol
Old Aug 24, 2005
ojay's Avatar
ojay is on a distinguished road
softer springs/springs with less of a drop
Old Aug 24, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Problem 1: Ground controls are stiff, on rough pavement they will bounce a little
Problem 2: Tokicos may not have enough damping to support the high spring rates
Problem 3: Tokico says not to go lower than 1.5", you went 2, with stiff springs and potentially underdamped shocks. You stand the chance of having blown the shocks leading to further bouncing.
Blown shocks and any springs won't ride any smoother. So before you think springs will solve it, figure out first if you already blew the shocks.
And rob... you got it backwards buddy. Change the word progressive for straight rate.
Old Aug 24, 2005
robbclark1's Avatar
sorry i thought he was running springs and not gcs...
Old Aug 25, 2005
Im pretty sure my struts arent blow yet tho. I was think about swap to Tein s.tech springs? Will my ride get any better with this set up?
Nalmonte
Suspension
Jun 9, 2015 07:08 PM
Optimus34
May 25, 2015 11:52 PM
vtec_concept
May 24, 2015 10:27 AM
JumpingBean
Nov 17, 2001 04:53 PM
MooCoW
Nov 9, 2001 05:22 PM
