installed new wire harness, now what?
Old Aug 9, 2005
I finally got my super nice suvlights.com H4 harness for the headlights. All plug and play, tested to increase voltage to the headlamps. Well I can't really tell a color difference or anything. I'm using philips vision plus (like stock clear), but they looked the same after. Maybe on our cars the wires aren't that bad in stock form?
Old Aug 9, 2005
dirtySAMURAI's Avatar
I log in from time to time
try putting in some 100w bulbs that'll make it look brighter.
Old Aug 10, 2005
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
All those wire harnesses are is a thicker wire.... so you will be able to run a higher wattage bulb safer and maybe pull more current to make it a tad brighter
Old Aug 10, 2005
ya i know. maybe i should get osram silverstar? I'm not sure if its legal here tho... they're clear and look similar to the usa sylvania silverstar so they must be putting alot more light out.
Old Aug 10, 2005
just get ricer bulbs, gearbox. you know you want ricer bulbs.
Old Aug 10, 2005
ya i have some raybrig 8k polar white lights on order haha
Old Aug 16, 2005
well the stock headlights look slightly whiter (which means they're brighter) now that I've seen em side by side with other stock cars. so yay its a good mod.
Old Aug 21, 2005
Dark_Pyro7's Avatar
Dark_Pyro7 is an unknown quantity at this point
so with this wire harness upgrade could you run the 4x mtecs without any problems??? how much are the harnesses? Are they really that helpful for higher wattage bulbs? I have TYCs in now, do they have anything for H1's? thanks
Old Aug 21, 2005
yes with the harness, you can safely run higher wattage without melting wires. But now the concern becomes melting your headlight. Especially with a small area in the projector, I've heard its best to use stock bulbs.
Old Aug 21, 2005
using the harness with regular watt bulbs will also make them brighter by increasing voltage as much as 2v, since stock wires are way too small.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Jon-Ohio
Jun 30, 2018 08:10 PM
01civyv3
Jun 2, 2015 05:21 AM
nicholaai
Apr 27, 2015 05:54 PM
Importracer
Nov 26, 2001 10:39 PM
