gauge question help!!
Old Aug 6, 2005
scarypunk's Avatar
scarypunk has a little shameless behaviour in the past
ok, i will be installing a voltmeter and oil pressue gauge .. what do i do?
**********edit
ive asked this before and was wonderin if someone could go into a little ( WAY MORE) depth when it comes to installing an oil pressue gauage ( machnical) and a voltmeter. I bought i new cluster bezel thingy with two pods on it. anyways i know about as much as getting to bezel off.. as far as wiring and finding the oil sensor and connecting it all together.. no idea
i know ill probably get flamed for 'being a n00b' or sometihng, but im just looking for some help.
2001 sedan dx
Old Aug 6, 2005
Michalo187's Avatar
Abortion Survivor
Tap into the oil pressure sensor just above the oil filter. Volt meter run a wire to your battery
Old Aug 7, 2005
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
^^ Scarypunk, can you figure that out or do you need more help?
Injen
Old Aug 7, 2005
scarypunk's Avatar
..i dont know ... its a little sketchy
( sarcastic much? )
Old Aug 7, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
for the volt meter just hook the yellow and red wire up to the yellow and red on your deck and ground the black wire
Old Aug 7, 2005
Michalo187's Avatar
Abortion Survivor
Look find the oil pressure sensor above the oil filter. Get a t-fitting that fits and tap it in. Its not difficult at all
Old Aug 10, 2005
streetglower's Avatar
for the voltmeter, it should just run to your battery. not sure on the oil pressure sensor since I have never installed one. But like everyone else said, it should tap into the oil pressure sensor. that sensor is located above the oil filter. there should be instructions with the gauge.
Old Aug 10, 2005
scarypunk's Avatar
and there is no instructions with the gauge
2001 sedan dx
Old Aug 10, 2005
blouisgod's Avatar
Life Begins > 6800rpms
what brand guage is it? all makers have websites with .pdf files that explain every gauge they make.
Old Aug 10, 2005
Redviking's Avatar
Redviking is on a distinguished road
Have you check that: http://www.7thgencivic.com/forums/sh...d.php?t=155267
Seems to be long and more complicated than expected, but well explained!
Old Aug 10, 2005
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
Oil pressure gauge install
Okay, don't have the Civic anymore, but did install gauges. So here is some information.
1. The wiring is pretty straightforward. Egauges.com has some nice installation instructions, so I will talk about things specific to the 7th gen.
2. The best place to mount the sender is on the fire wall with a bracket for two reasons. A. The sender is big and could break a fitting that is attached to the block, plus it lasts longer away from heat and vibration. B. The plastic intake manifold curves down, causing to be close to the port on the block.
3. The block is 1/8 BPT. This is not the standard 1/8 NPT that you can buy in stores.
A. Buy the following:
1/8 BPT male to -4AN male
3 foot stainless hose with -4AN 45 degree and -4AN straight ends (36 inches)
1/8 NPT male to -4AN adaptor
1/8 NPT tee
1/8 NPT male to 1/8 BPT female adaptor
B. Attach adapter and hose to allow senders to be mounted remotely. Use 45 degree end on block to allow to clear intake manifold.
Old Sep 17, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
Ok... could some one please explain how to do this for the dumb *** at hand? that dumb *** being me. Anyways, I read above, but its not so clear. Also, pics would be nice.
Old Sep 17, 2005
Blahman240's Avatar
bump, please some one answer the question in post 12
Old Sep 18, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
It doesn't get more self explanitory than that.
Old Oct 26, 2005
K20A_Wanabe's Avatar
K20A_Wanabe is an unknown quantity at this point
Can't you just tap into a wire in the wiring harness because i lost my sensor some how
Old Oct 28, 2005
Jap-Euro Fusion
For oil pressure?
No you need the sensor. The stock one is a yes/no thing looking to make sure the oil pressure is above some number. Autometer sells replacements.
Old Oct 29, 2005
AlienX's Avatar
AlienX will become famous soon enough
dude, if you can't do it, then dont do it. Get a pro to do it then because even if you feel like saving a couple bucks it seems like you are going to be making more of a headache out of it then its made to be. Now leave us alone and go to a shop!
knknif
Aug 4, 2015 06:11 PM
DerbyDad03
Jul 27, 2015 11:34 AM
Kyles24
Jul 16, 2015 10:14 PM
NoobyKid
Jul 13, 2015 07:53 AM
Kyles24
Jul 12, 2015 09:15 PM
