Oil leak
Oil leak
i changed my oil like 2 weeks ago and now i have a slight oil leak. there is a little spot under where i park my car. the oil never leaked before the change so im assuming i screwed it up. i looked under the car and it appears the oil is comming out of where the plug goes in the pan. after i changed my oil i found the DIY and i then realized that i didnt put a washer on in it. is that more than likely the problem. i may try to tighten the plug a lil more but i dont want to strip it. i put the plug tight but not real tight. any ways please help a first time oil changer out. thanks
DO NOT crank the bolt on. You'll stretch the threads in the pan. Go get the washer, its less than a dollar. You just wasted the oil, get 4 more quarts, change it again, put the drain bolt back in with a washer and torque it to spec (27 EX, 31 LX/DX).
Don't pour drained oil back into the engine.
Crayons taste like purple...
Originally Posted by puidokas
Mine is leaking out of the plug and my washer is on, anyone know how to fix this
LionSpratt
Jan 29, 2017 11:07 PM
RIPSAW
Nov 6, 2015 04:36 AM
Kyrian
Jun 26, 2015 11:48 AM
671civicLX
Jun 13, 2015 05:56 PM
