engine cut out at high rpms
Old Jul 31, 2005
peimp's Avatar
peimp is an unknown quantity at this point
hey guys, new here. i just bought an 02 civic lx with a turbo specialties t 25 extreme on it. while driving it i noticed that in higher rpms the engine will cut out like no gas is getting to it. When shifting in a calm fashion however, everything is fine. I then stopped the car and unplugged the connector ( the thing with like 12 different wires going into it) so that the turbo would not be operative. However, the problem is still there! any suggestions?
thanks!
jason
Old Jul 31, 2005
civic01vtec's Avatar
how much boost are you running ???
Sounds like you are running to rich.
Old Jul 31, 2005
peimp's Avatar
the thing is computer remote controlled, and thats what i need to figure out. i dont know how to adust it.
Old Jul 31, 2005
Try using the search function at the top of the page.
I'll leave this open for now......
http://www.7thgencivic.com/forums/sh...d.php?t=207055
http://www.turbodiscounters.com/html/fuel.aspx#
http://www.7thgencivic.com/forums/sh...d.php?t=218852
Old Jul 31, 2005
turboengnr's Avatar
DONT PANIC
just so you know, the turbo itself will always operate. It is not computer controlled.
So if you unplug anything, it will most likely result in damage to your engine.
Old Jul 31, 2005
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
i was wondering, I know turbos can only boost as low as the spring in the wastegate will allow. My question is do internally wastegated turbos usually allow for less boost than externally wastegated or vice versa or about the same?
Man you should not have started unpluggin things nor have bought an aftermarket turboed car, with out some experiance, or atleast some research. You could really f#ck your sh#t up.
Go to your local dyno tuner asap, and talk with him/her for awhile, and get it tuned.
Old Jul 31, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
is your check engine light on? ... does it blink when you're wot in high rpms?
if so, you may be misfiring... that's what happened to me
Old Jul 31, 2005
turboengnr's Avatar
DONT PANIC
no. the difference between an internal and external wastegate is its location and the way it operates.
you can buy lower psi springs for the external wastegates. But most internal wastegates are set at abou 4 psi. Why the hell would you buy a turbo kit, then run less than 4 psi?
Old Jul 31, 2005
TheSmuggler's Avatar
Originally Posted by civic01vtec
LMFAO please...
Old Jul 31, 2005
peimp's Avatar
the guy i bought it from said he ran with the brain unplugged for normal everyday driving. is there someplace i can go to view suggested setups for the turbo specialties remote?
Old Jul 31, 2005
From looking at all of your threads about your tubo, blown shocks and stereo not workin.....i say that bought the car from the wrong person.
Old Jul 31, 2005
jackburton's Avatar
To drive to get it tuned the first time, maybe turn it down in a summer heat wave, and i was just curious about external vs internal.
Old Aug 2, 2005
2K1Civic17"Gabe's Avatar
you definately bought from the wrong person. Dont ever drive anywhere with the unit unplugged. It should still have the settings saved, so plug that back in. And bring it to the tuners. Dyno wideband tuning is what you DEFINATELY need. You should sell the car as quick as possible, or put a new motor in there. That thing has run lean for a long time, and I dont know how its still running.
I have the same kit, use the damns ettings. There are links on this site for how to control it.
Make sure you at least unplug a pipe (not the one on the throttle body though, one elsewhere (not near the ground though). And hopefully filter it somehow. You dont want that hooked up. Thats the only way to not see boost, or open the wg?? or take the actualy turbo manifold off, but thats too damn loud/illegal.
Old Aug 2, 2005
peimp's Avatar
it runs fine, just at higher rpms it cuts out. i dont want to sell it, it runs fine 90 percent of the time, and if i had to guess i would think it would just be plugs or something. how much does it usually cost to have it dyno tuned?
Old Aug 2, 2005
between 150 and 80bucks a half hour. I pay 80 a half hour, takes an hour and a half give or take. so I pay about 260-300. They do an awesome job, but there is another place thats alright. They charge 150 to do a complete tune.
just shop around. Can you drive it hard, or does it just shut off? You want that unit hooked up, otherwise there is no added fuel to your engine. That will cause it to be lean, and blow your motor. if the unit isnt hokoed up, there is no power, and no info being sent to the injectors, causing no fuel. Unhook a pipe or something.... than get tuned and put the pipe back before the tune.
Old Aug 2, 2005
Originally Posted by 03-Acura-1.7-EL
btw: http://www.7thgencivic.com/forums/sh...d.php?t=220114
There few links on this topic here, try to search. To tell you from personal experience: Parts fit well, depends on your fuel option if its 1 or 2, both tricky to tune without a wideband. Install is straight forward, but study instractions for a day or so. Dont remember the page number, but somewhere on a picture TSI guys marked rdiator as a firewall and firewall as a radiator. lol, make sure you wont get confused on it.
Here is 2 helpful links:
Good luck!
P.S. Dont ask me how to tune the car, this is where I'm at now myself
click the links, the turbo discounters explains the fuel setup (the controller you unplugged). It tells you how to use it, and what all the functions are.
I hope this helps, and I wouldnt change the settings for the psi, or rpm. That is as long as there is something entered into the psi settings. at least to 7 or 10psi (incase of spikes)
Old Aug 2, 2005
peimp's Avatar
i can drive it fairly hard once its warmed up, but i am definetly planning on getting it tuned asap. can you clarify what you mean by unhooking a pipe? do you mean draining the fuel out of it? what exactly would you do to fix it? thanks bro!
Old Aug 2, 2005
Ryan2005's Avatar
Ryan2005 is an unknown quantity at this point
are you sure it's not the rev limiter
Old Aug 2, 2005
peimp's Avatar
so what fuel/air ratio do you run? and how long do you leave your injectors open?
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Ninetyatecivic
May 9, 2015 07:48 PM
Aznnp77
Dec 13, 2001 04:03 PM
ModNewbieHELPME
Nov 30, 2001 06:13 PM
spoony
Nov 7, 2001 11:01 AM
