changing led color
Old Jul 27, 2005
auratika's Avatar
auratika is an unknown quantity at this point
changing led color
how do i change a white led to have red output like red leds...? can i put a red film over it to make it more red?
Old Jul 27, 2005
evilone's Avatar
The Nightraid crew - Sensible Ownage
evilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the rough
desolder the white LED's, trace the circuit to the resistors for them, desolder the resistors, solder in proper resistors for the new LEDs (red LEDs have the lowest voltage/amperage requirements, so they need different resistors), solder in red LEDs, have a beer.
Old Jul 27, 2005
auratika's Avatar
i know i can do that but would there be some kind of dye/clear paint to use over the white leds..
Old Jul 28, 2005
dirtySAMURAI's Avatar
I log in from time to time
what would the point in that be? you would lose so much output and the color wouldn't be truly red...
Old Jul 28, 2005
you can't really filter led light. like if you have white leds behind a red lens, they will barely be visible.
Old Jul 28, 2005
silverem2's Avatar
what about red led's behind red lense? That works right? You have to just match up the filter color with the led color
Old Jul 28, 2005
yep. matching frequencies is best.
Old Jul 28, 2005
cause you have to remember, leds are only one wavelength. So if you filter it, you're left with nothing, unlike incandescent lighting.
Old Jul 28, 2005
auratika's Avatar
ahhhh.. i see, i guess i'll have to replace all the leds then..
MamaBear2015
May 27, 2015 12:04 PM
CraigW
May 24, 2015 09:49 AM
eorlando1
May 17, 2015 11:16 AM
Importracer
Nov 17, 2001 03:37 AM
