seamfoam brake booster hose where ???
Old Jul 25, 2005
return_2020's Avatar
return_2020 is an unknown quantity at this point
I am giong to try doing a seafoam for the first time in 03 civic with 45k miles. I need to know where the brake booster hose is on 03 civic ? plese provide pic if you can. very much appreciated. Thank you
Old Jul 25, 2005
2K1Civic17"Gabe's Avatar
the brake master cylinder is on the drivers side firewall. There is the largest resorvoir in that area, and its attached to the firewall. Probably has a darker colored fluid in there. (mine may need a flush). It connects to the brake pedal in the car. So right where the rod goes through the firewall, is where the master cylinder is. I would follow the lines to find the brake booster. Good luck, hope this helps! Ive never messed with my brakes, so I couldnt tell ya. Sorry.
Old Jul 25, 2005
midnightblueEX's Avatar
midnightblueEX has a little shameless behaviour in the past
I wouldnt even do seafoam. i did it and a few days later i got a 02 sensor code
Old Jul 26, 2005
Honda_trilogy's Avatar
Honda_trilogy is an unknown quantity at this point
I've heard similar stories from others.
I've never tried it because I never heard anything good about it.
Old Jul 26, 2005
What Happens Is, The Carbon Build Up Shoots Out Of The Exhaust And Messes Up The O2 Sensor (i Was Told)
Old Jul 28, 2005
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
It's got 45,000, do a valve adjustment, brake fruid and anti freeze.
OptimisticWay
Jul 10, 2015 04:31 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
General 7th Gen
Jul 9, 2015 10:17 PM
silentz
Jul 9, 2015 08:16 PM
Causemo
Jul 5, 2015 06:42 AM
