k20 swap help
Old Jul 22, 2005
ImportRacer2123's Avatar
K20 Member
k20 swap help
ok i have a little problem the bracket for the shifter cables that mounts over the heatshield is touching my dc sports race header. anyone have this problem? also i saw someone mount the battery on the subframe how was this done can somoene explain what was needed to do that?
Old Jul 23, 2005
EM2typeflex's Avatar
EM2typeflex is an unknown quantity at this point
^^I think you should buy the battery relocation kit to move it to the trunk.
Old Jul 23, 2005
K20 Member
hey kyle is there a site that sells one?
Old Jul 25, 2005
poor jaysun's Avatar
poor jaysun will become famous soon enoughpoor jaysun will become famous soon enough
The subframe mount was done by building a battery box that is wielded to the sub frame and the factory pegs are used with your choice of battery tie down. Only problem is if you decide to turbo it, your piping will run over top of the battery.
Do you have pictures of the cables. I never had a problem with my set up and I have a turbo sitting back there with a 3" downpipe.
Old Jul 25, 2005
HondaLuver's Avatar
Its a celebration bitches!
i stuck mine in the back since, i had a 0 gauge wire running threw my car because a system i had then took out because i hated how it my car heavy and slow...
im not sure about ur shifter cable, look for a way around it...
Old Jul 26, 2005
K20 Member
im using ep3 shifter cables but im doing a k20a3 swap. but something doesn't seem right.
Old Jul 26, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
will ep3 cables work? ... they have an in-dash shifter ....
Old Jul 26, 2005
civic2k2's Avatar
civic2k2 is an unknown quantity at this point
I would get a relocation kit and put the battery in the trunk. Will Si shift linkages work ?? Im having to get some custom ones for my swap, but I thought you would want to use a RSX linkage and not a Si due to the stock shifter location on them.
Old Jul 26, 2005
HondaLuver's Avatar
yea, i think you have to use the rsx ones, because they follow the same floor plan as a civic... unless you plan on putting your shifter like a si...
Old Jul 26, 2005
K20 Member
oh wait nevermind i remembered i got the base rsx ones I had a talk with the guy about that before i bought the RSX ones.
Old Jul 27, 2005
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
dude.. go to walmart and buy a marine battery box (about $5)to put in the trunk... mount the box to the floor... then go down to an audio store and buy some thick *** gauge wire ..better to buy a spool.. i bought it for $30.. then mount it to the back and run it all the way to the front...
ep3 linkage wont work.. too short
Old Aug 1, 2005
K20 Member
hey i have a new question for you guys... doesn't our returnless fuel system have 2 fuel hoses? because i have 2 hoses that are fuel lines but i don't know where to put the 2nd one. can someone help me out?
Old Aug 1, 2005
K20 Member
ok i got the shifter cables in and mounted i figured out the problem. But now it feels really loose when i shift the gears. it moves for 1st gear kinda moves for 2nd gear. but i don't think it shifts for 3rd gear. Did anyone that swapped a k20 into there car use RSX base cables? i have a feeling they are too long.
Old Aug 1, 2005
one goes to the fuel line the other is the purge line.. you should have 2 hoses on the motor side by side next to the one that goes to the fuel rail
Old Aug 1, 2005
i'll take pics tomorrow if nobody has it up by then
Old Aug 2, 2005
K20 Member
Sweet Man Thanks... Is your shifting kinda weird feeling? or is maybe because im used to driving my friends eg?
Old Aug 2, 2005
Dark2k1's Avatar
French ass K20a2 powered
Dark2k1 is an unknown quantity at this point
The EVAP line plug in the double metal tubing near the valve cover on the driver side. The big one is for the brake booster... and the other one is for your EVAP ... you can see near the intake a little black plastik bottle with a green valve...
About the shifter cable... you maybe have a trouble on your shifter box (inside the car) Check if every pin lock the wire is tight. Also check the bushing on the tranny.
Old Aug 2, 2005
K20 Member
can somoene send pictures of the shifter cables on the transmission? I think i might have mine on backwards.
Old Aug 2, 2005
you'll know if you have it on backwards by moving the shifter left and right as if it wasnt in gear.. if it feels like it goes in gear when you go left to right you got it hooked up wrong
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Scout1
Oct 5, 2015 01:33 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
