02 sensor extension for exhaust swap
i am about to do a lx-ex exhaust swap and i am told that the wires need to be extended on the o2 sensors. i know that the ground wires is shielded and was wondering if anyone has had any problems with the extension of the wires. or if they know of a place that makes a plug in extension?
had to extend the o2's they are not shielded. no problems. but i did have to remove the swaybar and i am replacing it with a ex sway bar. also thing you will need to do the swap are. the ex down pipe spring bolts and a 3 bolt 2.25" flange gasket with 1.5" bolts preferably 8mm bolt with 12mm head and nuts and washers.
its not a stock swap. i did a dc header ex, random tech cat pipe ex, and greddy evo 2 ex. the reason for doing this is keeping it smog legal. this way i still have a cat and eo carb #'s for everything.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
juror
May 26, 2015 06:35 PM
Civic4ever1996
Apr 16, 2015 08:30 PM
