Blown/Broken Engines
Old Jul 20, 2005
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
I just want to make a thread out there to get a list of people who have blown their engines/drivetrain because of Forced Induction or from serious N/A mods. This can be anywhere from headgaskets, intake manifolds, transmission failures etc. This is just for information purposes so people can maybe see some of the weak spots for the 7thgen civics and maybe the dangers of heavily modifying and also so we can learn from mistakes made my other members. When you post please tell us the details such as mods (PSI if boosting, nitrous shot etc) and what all broke and whatever else you may think is useful!
Old Jul 20, 2005
turboengnr's Avatar
DONT PANIC
ha.
Broke car on 4 psi (head gasket)
Custom kit with air-water intercooler
The water line on the air-water came off, drained the water out. Hot intercooler superheated incoming air, hot air caused detonation
Broke my car on somewhere between 7 and 9 psi of boost.
Custom turbo setup
Ported cylinder head
SF fuel system (damaged injectors, went lean, broke pistons)
Old Jul 21, 2005
mkingk2's Avatar
mkingk2 is an unknown quantity at this point
Originally Posted by turboengnr
ha.
Custom turbo setup
Sounds like you've had fun
Old Jul 21, 2005
civicskater's Avatar
Chicks dig my scent
blown transmission back in feb. my ACT clutch was burnt to hell and the throwout bearing was shot (so far my exedy has been great), the synchros in 2nd and 5th gear were gone. So had to replace the tranny....engine is strong, seems to me the weakest link is the transmission..i was running between 5-12psi on it before it went. Started noticing the clutch slipping and 2nd gear going out around mid jan.
Custom turbo kit (T28 w/ internal waste gate)
Weisco pistons, crower rods, ARP head studs
Old Jul 21, 2005
turboengnr's Avatar
DONT PANIC
oh yea....
i broke an act 6 puck clutch (clutch disc came apart)
i burned up a centerforce dual friction clutch and pressure plate
i broke my transmission
Old Jul 21, 2005
exturbo6's Avatar
blew my headgasket at 6psi.
Old Jul 21, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
broke an axle at 8psi.
Old Jul 21, 2005
2K1Civic17"Gabe's Avatar
do you have a link to the place you ordered your new ones from? I remember you have the performance ones (that werent in their system online, or possibly the store). How much did they run you? Thanks a lot, PM would be chill
Peace
Old Jul 21, 2005
Syke Fu's Avatar
Syke Fu will become famous soon enough
Wow. Were do you guys get the money to fix what was broke. I'm so broke that if something broke i be biking everywhere.
Old Jul 21, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
blew up my headgasket once at 13 psi ... blew it up again at 15 psi
Old Jul 21, 2005
scansel912's Avatar
How much does a Headgasket replacement usually go for in labor, parts, etc?
Old Jul 21, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
the headgasket is like a flat papery or rubbery like substance. in my buick it cost 30 bucks for the rubber seal. then labor is a couple of hours.
Old Jul 21, 2005
Havok2k1's Avatar
Wicked Pissah Admin
This might help a little too
http://www.7thgencivic.com/forums/sh...d.php?t=190918
Old Jul 21, 2005
turboengnr's Avatar
DONT PANIC
head gaskets run about $20 for stock replacement.
You can install it yourself for pretty much nothing. If you have a shop do it, expect to pay them a few hundred bucks.
You can do it in one day if it is your first time. If youve done it before, you can do it in a matter of hours. Some people can finish it all in under 2 hours.
Old Jul 22, 2005
robo1040's Avatar
Once you go Black on Black, You Never Go Back.
robo1040 will become famous soon enough
blew the headgasket a week after i was turboed, 8psi
spun a rod bearing the other day, 10 psi and a oil leak
Old Jul 22, 2005
andyman97's Avatar
Turbo Guru
I'm on my 3d engine.
1st went because of a coolant line being pinched.
2d never blew but had a bad oil leak from the oil sensor hole being stripped.
3d is currently about to be tuned.
Old Jul 22, 2005
HondaLuver's Avatar
Its a celebration bitches!
uhh... auto tranny... i drove like a crazy man... lol... now i have moved on
Old Jul 22, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
Spun 3 rod bearings at 14-15 psi @ 7300. hehe. Pretty well tuned with the EMS. Boost spike, old oil, and too much power are to blame. Shoulda remembered to set the boost cut on the EMS. Sucks when you have everything at your fingertips and dont use it. Dohh!
Mods included; ported D16y8 manifold with d17 TB ported, DSM 450ccs, aeromotive FPR, 255 walbro, kms valvetrain, ARP head studs pn#208-4301, oem head gasket, blockguard, AEM EMS, zeitronics wideband, clutchmasters stage 1 clutch, aluminum flywheel, HP turbo kit. T3/T04. Greddy type s bov, tial 38mm wg. custom 2.5 inch exhaust with no cat. No ps or AC.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
bluecoupe
Jan 23, 2002 05:50 PM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
Cross
Jan 6, 2002 01:31 AM
supercivic01
South
Nov 30, 2001 11:27 AM
