Fuel Injector Cleaner?
Old Jan 29, 2002
klam's Avatar
klam is an unknown quantity at this point
Does anyone use a fuel injector cleaner additive? The ones your supposed to add every time you change your oil? Is this a good practice or do natural detergents in gasoline already do that? Are there any side effects of adding fuel injector cleaner?
Old Jan 29, 2002
GTekCiViC's Avatar
GTekCiViC is an unknown quantity at this point
yea those things work... and it's a good idea........ but my car is still NEW
so i won't use it until i notice a little sluggish pull on my car
Old Jan 29, 2002
Jimmy24's Avatar
Jimmy24 is an unknown quantity at this point
You got to check that in the manual but, if you use gasoline with cleaning additives you should be good!
Old Jan 29, 2002
Grey's Avatar
DIY King
I use STP fuel injector cleaner every other time I fill up. It prevents buildup of deposits inside of the fuel injectors and fuel lines. Good stuff. Pretty cheap for what it does. Get the weaker stuff and use it every other day. It should be about $1.50 - $2.00 per bottle.
Old Jan 29, 2002
Jimmy24's Avatar
I got to check in the manual but I think it tell ya not to use them things[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Jan 29, 2002
Grey's Avatar
DIY King
Nah, pg. 162:
<< We reccomend gasolines containing detergent additives that help prevent fuel system and engine deposits. >>
The stuff that I mentioned does just that. It helps to prevent fuel system deposites. [IMG]i/expressions/beer_yum.gif[/IMG]
Old Jan 29, 2002
drbombay's Avatar
drbombay is an unknown quantity at this point
if you just buy the 92 oct at cheveron it has more cleaners. it's just about the same price as buying a seperate cleaner.
Old Jan 29, 2002
ILLWILL's Avatar
ILLWILL is an unknown quantity at this point
those things r great for peeps who use cheap gas
Old Jan 29, 2002
jonavin's Avatar
jonavin is an unknown quantity at this point
I used to use injector cleaners on my old Altima. It helps. You just have to remember to run the whole tank with it, otherwise you'll diluted if you fill your tank with new gas before it's empty.
These days I don't nother use injector cleaners. Once in a while I just put in Sunoco 94 instead. It's easier, and in reality it doesn't cost anymore.
SimpleUser
Apr 24, 2021 02:54 AM
SuperNova18
24
Sep 2, 2019 10:46 PM
fred57
Aug 1, 2015 08:45 AM
Green02civic
Jul 27, 2015 10:48 PM
jody501
Jul 10, 2015 11:01 AM
