help install vafc2!
Old Jul 13, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
help install vafc2!
I'm using this diagram right here...
http://www.7thgencivic.com/forums/sh...highlight=vafc
Sooo let me get this straight.
red
black
brown
grey
light blue
blue
purple
white
Are those the only wires we use? I'm not sure about the input and output wires... btw I got my vafc2 used. So I have no manual.
are the pink and yellow wires used?
Old Jul 13, 2005
Blahman240's Avatar
ohhhh I see... you cut the wire, and put it to the input, then the output wire goes back to the ecu.
Old Jul 22, 2005
Valdeezy's Avatar
Valdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to all
unless you know exactly what ur doing I would not do this urself. when I tried I didnt get the wires right and when the enginestarted it was bad. so I took iot in had it done right and had it dynoed. If you dont get ur car dynoed and set up correctley then u will never be able to lower your engagment point. after the dyno I am now able to kick the vtec in at 2400 and low cam kicks in at 2200. and now when the vtec kicks in I can tell a huge difference when I start to pull out of 1st gear. definatley get it to a dyno.
Old Jul 22, 2005
Blahman240's Avatar
I planned on it... I also think I'm going to get the vafc2 obd2 harness for out cars... it'll be ten times easier.
Old Jul 22, 2005
if you can't follow that detailed post with all the info there, you shouldn't install it. Its just a very easy thing to mess up and then you'll be out $1000 for a new ecu. I sure hope you remember to unplug the battery because those are LIVE wires that can kill you! Honestly, its not worth it. I had mine dyno tuned, gained 2whp with some moderate engine work. Changed one little thing and now the a/f is way off again and needs to be retuned. as for vtec engagement, its a very bad idea to change it. alot of conditions need to be met before the stock ecu can activate it such as oil pressure, full throttle, rpm, etc. it can be very bad if you just set it to engage at one rpm instead of variable and it can ruin your engine if it engages at lower oil pressure.
Old Jul 22, 2005
Blahman240's Avatar
It is worth it for me... its the cheapest alternative for my turbo setup.
Old Jul 22, 2005
wow thats gonna suck tuning it for turbo and even then you'll only get a good tune at WOT if at all.
Old Jul 23, 2005
ajhdragon's Avatar
7thgens official a$$hole
eww why vafcII for turbo you should have just saved a little more. really the only good thing it is good for is for lx/dx to ex head swap. kind of like me but im running a dx ecu with a d17a2.
Old Jul 27, 2005
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
lol... agree with this guy.. dont think it could be explained any easier
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
