Maximum HP from a D17A1?
Old Jul 12, 2005
brandon4455's Avatar
brandon4455 is an unknown quantity at this point
Exclamation Maximum HP from a D17A1?
Hey guys, I'm a new civic owner (2005 value package) and I'm wondering what I can do to squeeze the most HP out of my engine, and what possibly is the highest HP possible with this engine?
I'm looking to put in cams, heads, exhaust, intake, valves, turbo, nitrous, whatever it takes.
Thanks in advance.
Old Jul 12, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
you could make it as high as you want as long as you have the money for it. for the right amount i would say 250+
Old Jul 12, 2005
start with pnp head work, valves, cam, retainers, cam gear, i/h/e, but keep in mind you have to build it for what you want either na or turbo. A bolton turbo kit will net around 150whp (stock is below 100) but might not last very long.
Old Jul 12, 2005
Well, if a turbo is gonna tear up my engine that badly I probably won't put it on. How much HP do you think I could squeeze out, with just parts if I stayed normally aspirated?
Old Jul 12, 2005
se7engen_riDe's Avatar
se7engen_riDe is an unknown quantity at this point
^ why would it not last very long?
Old Jul 12, 2005
White05EXSE's Avatar
White05EXSE is an unknown quantity at this point
....swap to an ex engine.
Old Jul 13, 2005
MajinB's Avatar
head swap to ex engine. turbo it with pulleys i/h/e lsd and aem plug + play. around 200hp. then nitros with 50 or 75 shot. 250-275. all the stuff gearbox said would help bump the hp to 300. all together 300+
Old Jul 13, 2005
As in the original message, I meant horsepower out of this engine right now, not a new engine.... how much can I get out of a normally aspirated D17A1?
Old Jul 13, 2005
MajinB's Avatar
200 all motor. maybe 250. it would be expensive
Old Jul 13, 2005
How expensive are we talking for 200 horses? I'd be content for life if i could get 200 horses out of this car.
Old Jul 13, 2005
the highest any member has reached na was around 140whp. civic ex, pnp head, valve job, i/h/e, hi flow cat, cam gear, vafcII all tuned on the dyno. I can't imagine even coming close to 200whp na. there's no way.
Old Jul 13, 2005
MajinB's Avatar
ok nevermind then. i thought if you get cams and valves and high compression pistons it would help alot.
Old Jul 13, 2005
....140 to the wheels wouldn't be slow man.
ex convo. shouldn't be too much;
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7986466428
Old Jul 13, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
as of now, I dont think any D17 is up to the 300WHP or 300BHP mark... thats unheard of..... By that time, some sort of reinforced tranny would be needed. The best choice here is a K20A2 swap... sorry, D series is just an engine meant for high MPG, not much power, and long lasting.
Old Jul 13, 2005
2K1Civic17"Gabe's Avatar
300 has been reached on a d17 I forget if it was to the wheels or bhp
Old Jul 13, 2005
civic01vtec's Avatar
it was whp at 18psi
the tranny limits our motors.....anything over 250whp is asking for trouble with the tranny.
Old Jul 13, 2005
i think it was 300 whp from SF power.
Old Jul 13, 2005
yup, you guys know whats up. It can be done, but the tranny is the major problem. Nothing for them yet. Cryo treat the tranny is about the only way right now isnt it? I could be wrong, havent been online as much the last month or two. could be new parts?
Old Jul 13, 2005
zachgeyer's Avatar
i will have 180 are so
Old Jul 13, 2005
Catalyst never posted dyno sheets
Barney made over 300whp
Old Jul 13, 2005
wow, I stand corrected. Built motor?
Old Jul 13, 2005
http://www.7thgencivic.com/forums/sh...8&postcount=23
Old Jul 13, 2005
How easily could I reach 150-200? If I could get 200 out of this D17A1 without turbo or nitrous, I'd be 100% satisfied. Actually I'd be satisfied with 170ish, but 200 would be PERFECT.
Old Jul 13, 2005
MajinB's Avatar
dude, any motor can be meant for anything. as long as you have moola its all good. anyways, k20 is overdone and im not saying uneffective but way over done. id rather take the road less taken and build the hp. more respect that way. and a 250 hp 2500 pound car sounds fast as all hell to me. lol.
Old Jul 13, 2005
MajinB's Avatar
btw whoever repped me, thanx
Old Jul 14, 2005
jttegx's Avatar
OMNES AD UNUM
Thanks in advance.
if your planning to swap, youll definately love the rsx-s complete swap (k20a2). if money isnt an issue that is (which im assuming isnt since it sounds like your willing to cash yourself out on this civic). but of course, itd defeat the purpose of buying the "new" civic.
i think your best bet of getting high hp numbers is the turbo route. sorry to say, i dont think there is any way your going to get 200hp going n/a...
Old Jul 14, 2005
150 is reachable but 200 is way out of reach unless you have major money. I have never seen a 200whp n/a streetable sohc motor.
Old Jul 15, 2005
Is there any way to turn this motor into a DOHC? Or would that require a lot of rebuilding to have two cams?
Can anyone list me some parts that I'd need to get 150 out of this engine NORMALLY ASPIRATED. Exhaust, cams, whatever I need, just list them for me and maybe where I can find them for 150horsepower, and I'd be ever so grateful. Thanks.
Old Jul 15, 2005
Redline04's Avatar
AKA Mr. 60ft. Not to be confused with Civic_Redline
Redline04 is an unknown quantity at this point
I have a 2004 VP. I made 111whp with I/H/E crank pulley, and no power steering belt. Not much to brag about. A little weight reduction and some practice can get you into the 15's easily, but still aint ****. N20 is the cheapest way to make a D17 faster. Dowside is you can only use it for short intermitent runs. At the same time you are not constantly stressing your motor. Like I said as far as straight line and 1/4 mile performance N20 will net you the biggest hp gain per $$$. All motor D17A1 will cost probally as much as a turbo and you might make 150hp if your lucky. K20 is bad *** but lots of money $$$$. Could buy 10 D17s and run a 75 shot on each of them till they blow for the same price. It all comes down to money and preference. If you got the money you can make anything happen.
Old Jul 15, 2005
I can't afford the price of ruining my car to put nitrous in it. I really need to find someone who can help me work with the tranmissions. I have the 5spd manual deal, but for first gear, I can barely get to 10 or 15mph before it starts to sound like the engine's gonna blow, so basically I just don't even use 1st gear, I just take off from 2nd. Are there any modifications I can make to the clutch or shifter, or the gear ratio's to make my takeoff speed more efficient, as is right now?
