power stearing
Old Jul 6, 2005
nova4dr_racer's Avatar
nova4dr_racer is an unknown quantity at this point
power stearing
my stearing becomes very hard when I turned it at low speed (parallel parking, etc.) I suspect it to be my power stearing that is dead or something but it doenst do it all the time but most of the time. Does anyone know what it might be? and if it is the power stearing does anyone know how I can fix it myself?
Old Jul 6, 2005
Victorious's Avatar
Victorious will become famous soon enoughVictorious will become famous soon enough
will if your power steering is dead or no fluid at all it should be extremely hard all the time, not some of the time
im not sure what your situation can be... sorry
anyone else?
Old Jul 6, 2005
soonercivic's Avatar
soonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the rough
Well it is harder to turn a slow/non moving tire because there is more resistance from the road and tires. Like Victorious said, if it was dead it would be doing it all the time. First check your PS fluid and make sure its full, if not fill it up. If it is, and your car is under warranty, take it to honda and tell them to look at it. The PS pump either works or not, it doesnt go on and off.
Old Jul 6, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
If the fluid is low it will do that. Or if the pump is failing, or your car is idling to low for some reason. Its probably because to fluid isnt pumping fast enough at low engine speeds.
Old Jul 6, 2005
where is located the ps fluid so I can check it out?
Old Jul 6, 2005
02fpcivic's Avatar
hmmm I dont have one anymore but I tink it was on the driverside wheel well. Its got a hose going to the PS pump though, it should be pretty easy to spot.
Old Jul 6, 2005
^^^If you have the D17 engine (not si or RSX) then the resevior is located on the drivers side up near the windshield. There are 2 up there, one if PS and one is brake fluid. If your checking one, you might as well check both, odds are good if one is low both are. There is a line on the side that says "max" and one that says "min".
Old Jul 6, 2005
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
Actually the power steering reservoir is the grey with red cap reservoir just behind the driver's side headlight. The two reservoirs at the firewall are brake fluid and clutch fluid (for manuals only).
Edit: Added pic
Lower right hand corner next to PS pump. Grey res w/red cap.
Thanks to waross for his perfect picture.
Old Jul 6, 2005
My bad. i cant believe i said that wrong. I even checked mine the other day. Now i feel like an idiot. stupid stupid stupid.
Old Jul 6, 2005
bobsagator's Avatar
lol...two eyes are better than one, or two sets, whatever...
Old Jul 6, 2005
im sofa king we todd id!
Old Jul 6, 2005
02fpcivic's Avatar
I wasnt much help either because I stripped the ps two years ago hehe
Old Jul 7, 2005
bobsagator's Avatar
Not to steal this thread, but did you just pull and cap the lines to the rack or did you install a breather? I have been wanting to ditch the ps for a long time now, just too lazy to find a breather. I think some of the fluid in my rack has evaporated since it seems to be turning easier these days and the belt has been off for months.
Old Jul 7, 2005
02fpcivic's Avatar
I had the lines disconnected and open and I drained only enough fluid so it wouldnt come out of the lines but im gunna do the breather deal before I stuff the new engine in seeing how its so easy to get at. For some reason our cars are harder to steer than most of the prev gen stuff when the ps is disconnected. My boys 4 door accord steers way easier than mine and he has his stuff off from when he did h22a swap. Its only a problem till your muscles get used to it anyways. My gf got used to it so I bet anyone else can.
Old Jul 8, 2005
ya .. hope u dont have large wheels cuz it only makes it harder! i checked my ps fluid and its good. oh hell with it .. ill check take it out
Old Jul 8, 2005
eyegiant's Avatar
eyegiant is an unknown quantity at this point
he means this.......
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
kmarcet
Sep 26, 2015 10:25 PM
Dave1984
Jul 22, 2015 06:10 PM
breanna_17
Jul 21, 2015 04:01 PM
