Need help to finish broke lug stud installation
Old Jul 1, 2005
gnat1000's Avatar
gnat1000 is an unknown quantity at this point
Well I got the new stud installed but I need to know how much to torque the main screw bearing that is behind the stud it is number 5 on this pic.
Old Jul 1, 2005
streetglower's Avatar
what do you mean main screw bearing? DO you mean the spindle nut?
Old Jul 1, 2005
gnat1000's Avatar
yeah the main bearing.
Old Jul 1, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
The axle nut is something crazy. I think its 125 lb-ft + another 1/4 turn, then swage the nut on.
#5 in the pic is the wheel stud, and you just press those into the hub then torque the wheel on to 80 lb-ft as usual,
Old Jul 1, 2005
gnat1000's Avatar
the nut i'm talking about is the big brass looking nut that is in the middle in the very center of the hub assembly
Old Jul 1, 2005
yes that is the spindle nut, and it is torqued to 134 ft. lbs. And you need to use a new nut after the first was tooken off, and make sure you make a punch in the nut to have it hold.
Old Jul 1, 2005
gnat1000's Avatar
ok why would i need a new nut and why would i need to punch it?
Old Jul 1, 2005
it is just one of those nuts that needs to be replaced after it is tooken off. Just like they recommend using new head bolts when the head comes off. The bolts will tend to stretch after use and reusing them will cause them to back off the torque amount, well the same goes with this nut. And if you look at the splines on the spindle, you will see a slot in it. When the nut goes on, you are supposed to indent a portion of the nut into that slot to hold the nut on without it backing off. Just use a puch or something to indent the nut.
Old Jul 2, 2005
Jap-Euro Fusion
Its a swaged nut, you effectively destroy its reusability when you swage it.
Swaging it (or "punching it") is a safety feature that locks the nut in place. It keeps it from backing out.
BootyDo
Jun 21, 2016 03:45 PM
Misfit2613
Jul 30, 2015 09:49 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
AaronSorenson
Jul 7, 2015 09:40 PM
