How many valves?
Old Jan 25, 2002
2k2civic's Avatar
How many valves?
In the civic SOHC engine, there are only 2 valves/cylinder, right?
Old Jan 25, 2002
Nitek's Avatar
Nitek is an unknown quantity at this point
4 valves per cylinder.
Old Jan 25, 2002
2k2civic's Avatar
Thanks.
Old Jan 25, 2002
Grey's Avatar
DIY King
16 valves total.
Old Jan 25, 2002
2k2civic's Avatar
I want 6 valves and 2 spark plugs per cylinder. Why? Cause I wanna be different. LOL, no seriously though, I do wanna be different and that's why I wnt that DOHC head swap.
Old Jan 25, 2002
AFlyer's Avatar
AFlyer is an unknown quantity at this point
wow, never heard of 6V per cyl, the most i've heard of is 5 in the audi 40V engines. good luck with that!
Old Jan 26, 2002
Dakker's Avatar
Giggity Giggity
Dakker is an unknown quantity at this point
6 valves?? bah just get one BIG intake valve and one BIG exhaust valve, then you can say but its only an 8 valve 4cyl it has to be slow[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Jan 26, 2002
2k2civic's Avatar
How much would it cost to have a custom built 20 valve DOHC head?
Old Jan 26, 2002
Grey's Avatar
DIY King
Too much man. Just think of all the fabrication. The control system for that extra valve. New pistons. Extra valve. Different camshaft. Weird setup anyway, why have that extra valve? What could you do with it? Four valves per cylinder seems optimal to me.
Old Jan 26, 2002
2k2civic's Avatar
I don't plan on getting a custom made cylinder head anyway, just wondering. But I really do plan on swapping to a DOHC head and then get a turbo. Think about how much better things will perform when you can adjust the intake and exhaust valve timing independant from each other.
Old Jan 26, 2002
blouisgod's Avatar
Life Begins > 6800rpms
normally, sohcs only have 8 valves but our d17y carries 4 valves/cylinder
Old Jan 28, 2002
Jimmy24's Avatar
Jimmy24 is an unknown quantity at this point
I've never seen 8 valves per cilinder, I will assume you are joking!
Old Jan 28, 2002
Jimmy24's Avatar
Our civics have 4 valves per cilinder, 2 for intake, 2 for exhaust.
The difference between SI vtec and EX 2K1 vtec is that one is for performance and the other one is for gas saving!
While the SI opens the valves more when it engages the vtec, The Ex 2K1 is working with 3 valves between 0-3000 rpm's +-.
as soon as you pass between 2500 and 3000 rpm's, intead of using one valve for intake, it uses 2. So...... the car is a 12 valve per cilinder and it turns into a 16 valve per cilinder when it pases 3000, depending on some variables too!
And that's why people with EX's don't feel vtec engagement point as other DOHC Vtec's.
[IMG]i/expressions/beer_yum.gif[/IMG]
h4ldol
Apr 24, 2017 08:16 PM
rallyeredem0
Nov 2, 2015 10:56 PM
Hutch1051
Sep 29, 2015 09:20 AM
Bruce2
Sep 27, 2015 08:45 PM
BJB
Sep 14, 2015 11:16 PM
