A/C compressor on and off
Old Jun 6, 2005
js89x's Avatar
js89x is an unknown quantity at this point
I recently bought a new 2005 Civic LX 4sp, and I've noticed that when I run the A/C the compressor seems to turn on and off. It's usually about 15 seconds between cycles. I seem to notice it more at high speeds on smooth freeways than I do at slower speeds. The temp of the air blowing out of the vents remains steady, though. Is this on/off something that's normal?
Old Jun 6, 2005
normal
Old Jun 6, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
it happens, only uses it when it needs it
Old Jun 10, 2005
xxhonda4lifexx's Avatar
xxhonda4lifexx has a little shameless behaviour in the past
really??? never knew that. What a convenient gas-saving feature
Old Jun 10, 2005
dnbguy86's Avatar
dnbguy86 is an unknown quantity at this point
You shouldnt be able to tell when the compressor kicks in on the highway, if you do you have a serious problem.
Old Jun 10, 2005
well yea you can. it makes a noise when the fans turn on and you can hear it click on. also voltage will drop and air flow is affected for a second.
Old Jun 10, 2005
js89x's Avatar
Yeah I can hear the quiet click, but I never notice any difference in air flow. The only time I notice a change in voltage is when the car is in idle and the headlights dim for a second. I'm just going to assume all is normal.
Old Jun 10, 2005
you can do a trick. Hold the power window buttons up even after the window is rolled up. You'll see tons of dimming but yea all normal. the a/c just takes alot of voltage from the alternator as well as engine power.
Old Jun 10, 2005
AzNTiG3R's Avatar
Member
AzNTiG3R is an unknown quantity at this point
isn't it bad to turn on/off the AC while driving? that's what I heard....
Old Jun 10, 2005
yea its bad for the compressor to click on at hi rpms. Eventually it will break something. that said, having ac on means it will switch on/off anyway. then again they also say the chemicals eventually corrode the pipes. One member is using envirosafe instead of r134a and its supposed to be alot better for nature and not corrode anything.
Old Jun 11, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
when you use a/c it makes your car use alot more gas. you lose one of your cylynders just to power the a/c. when i say lose i mean it drains 25% of your engines power. in my old buick you couldn't feel it cause the engine was big but in my 01 ex 5sp you can feel a difference.
Old Jun 11, 2005
js89x's Avatar
How high rpms are we talking about? Last week while driving up a steep hill I was running the A/C and the rpm was about 4500 for a minute or so. I also remember reading in a previous topic that the compressor doesn't come on while the car is accelerating quickly, although I'm not sure if that's true or not.
Old Jun 11, 2005
if the pedal is far down enough, it turns off. Like if its on at a light and you floor it or give it some good gas, you can feel it kick off until you're done. I would guess over 4k rpms is bad, but again it doesn't happen once. It does take a while and repeated on/off at hi rpms to break.
Old Jun 11, 2005
AzNTiG3R's Avatar
Member
well for stick, i heard u can just push the clutch down and turn the AC on/off while driving, but for autos, the best thing to do is turn it on when the car is at a dead-stop.
Old Jun 11, 2005
yea but the compressor still turns on and off automatically when you drive.
Old Jun 12, 2005
js89x's Avatar
Most of the driving I do is on the freeway, and I usually wait and turn on the A/C once I'm on the freeway and going at a steady speed. I like the extra power for the acceleration, and I always assumed that would be better for the car too. That hill I drove up last week turned out to be steeper than I thought, and the car really downshifted. I just hate that I may have caused premature wear on the compressor.
Old Jun 12, 2005
MajinB's Avatar
listen try to drive with the windows cracked and let the outside air be pulled in through the vents without using the air. or do that without using the compressor. or just roll your windows down. if you need air all the time you bought the wrong car.
Old Jun 14, 2005
AzNTiG3R's Avatar
Member
Scout1
Oct 5, 2015 01:33 PM
JMKendrick
Sep 16, 2015 06:17 PM
MommaLiz
Sep 7, 2015 10:42 PM
JJ291
Sep 2, 2015 11:49 PM
