A/C compressor on and off
I recently bought a new 2005 Civic LX 4sp, and I've noticed that when I run the A/C the compressor seems to turn on and off. It's usually about 15 seconds between cycles. I seem to notice it more at high speeds on smooth freeways than I do at slower speeds. The temp of the air blowing out of the vents remains steady, though. Is this on/off something that's normal?
well yea you can. it makes a noise when the fans turn on and you can hear it click on. also voltage will drop and air flow is affected for a second.
you can do a trick. Hold the power window buttons up even after the window is rolled up. You'll see tons of dimming
but yea all normal. the a/c just takes alot of voltage from the alternator as well as engine power.
but yea all normal. the a/c just takes alot of voltage from the alternator as well as engine power. Joined: Sep 2002
yea its bad for the compressor to click on at hi rpms. Eventually it will break something. that said, having ac on means it will switch on/off anyway. then again they also say the chemicals eventually corrode the pipes. One member is using envirosafe instead of r134a and its supposed to be alot better for nature and not corrode anything.
Drunken Master-7thgen Ninja
when you use a/c it makes your car use alot more gas. you lose one of your cylynders just to power the a/c. when i say lose i mean it drains 25% of your engines power. in my old buick you couldn't feel it cause the engine was big but in my 01 ex 5sp you can feel a difference.
if the pedal is far down enough, it turns off. Like if its on at a light and you floor it or give it some good gas, you can feel it kick off until you're done. I would guess over 4k rpms is bad, but again it doesn't happen once. It does take a while and repeated on/off at hi rpms to break.
Originally Posted by AzNTiG3R
well for stick, i heard u can just push the clutch down and turn the AC on/off while driving, but for autos, the best thing to do is turn it on when the car is at a dead-stop.
listen try to drive with the windows cracked and let the outside air be pulled in through the vents without using the air. or do that without using the compressor. or just roll your windows down. if you need air all the time you bought the wrong car.
Scout1
Oct 5, 2015 01:33 PM
JMKendrick
Sep 16, 2015 06:17 PM
MommaLiz
Sep 7, 2015 10:42 PM
