Ported throttle body
Old May 27, 2005
Michalo187's Avatar
Abortion Survivor
Is it possible to get our stock throttle body and port it out? If so how would this be done? i would really like to know so i could try this and not have to buy one for 300 or more dollars
Old May 27, 2005
dannn's Avatar
unique conformist
dannn will become famous soon enough
port?
i never heard of porting a tb
do you mean bore?
yea there was a guy that did it
i dont know if hes on here still.
Old May 27, 2005
www.maxbore.com $100
It is awesome work. I did it a while back but it lost power. Later I found out that auto and manual tranny uses different throttle body sensors. I was trying to use a manual with my auto and didn't work. I'll prolly send mine in again once I figure out if it will work with the intake I'm getting.
before
after
Old May 27, 2005
dannn's Avatar
unique conformist
you lost power?
is it cuz you used the wrong tranny tb?
Old May 27, 2005
yea. make sure you use the correct tb. The sensors work with the ecu (also dependent on tranny) and using the wrong one causes poor throttle response. I mean a few mm porting should not cause any hp loss. Normally, you should gain at most 5whp arcoss the power band.
Old May 27, 2005
Michalo187's Avatar
Abortion Survivor
dam thanks dude i appreciate it and port and bore pretty much the same? If i get this would have to re dyno tune?
Old May 27, 2005
its a full port and polish. same as bore. might need dynotuning
Old May 27, 2005
blouisgod's Avatar
Life Begins > 6800rpms
Damn maybe ill try a diy for this
Old May 27, 2005
Michalo187's Avatar
Abortion Survivor
hahahahah go for it man if you got good it would be a good way to make some money i wonder how hard it could be
Old May 27, 2005
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
That is a beautiful job for $100! Looks sweet.
Old May 27, 2005
blouisgod's Avatar
haha, ill see what tools i can find for my dremel.
Old May 27, 2005
blouisgod's Avatar
damn that maxbore guy has his **** together. has anyone tried to swap tbs from other models to the d17?
Old May 27, 2005
h0nd4_r1c3r_X's Avatar
h0nd4_r1c3r_X has a little shameless behaviour in the past
i did it myself with a dremel ... ust dont mess it up like i did.. take the sensors out
Old May 27, 2005
um i don't think this is a simple dremel job. You'll never get it even all around. I hope you're joking.
Old May 27, 2005
blouisgod's Avatar
hahaha, to bad i dont have a lathe
Old May 28, 2005
Michalo187's Avatar
Abortion Survivor
Could you use a brake lathe???? I don't know what that is but i know we have one in auto mechanics class? I gotta try this ****
SammySC
121
Apr 7, 2017 07:43 PM
carid
Sep 28, 2015 10:13 AM
Bruce2
Sep 27, 2015 08:45 PM
2.0.0.2
Sep 14, 2015 06:38 PM
Bricoleur
Sep 9, 2015 12:30 PM
