Ported throttle body
Abortion Survivor
Is it possible to get our stock throttle body and port it out? If so how would this be done? i would really like to know so i could try this and not have to buy one for 300 or more dollars
www.maxbore.com $100
It is awesome work. I did it a while back but it lost power. Later I found out that auto and manual tranny uses different throttle body sensors. I was trying to use a manual with my auto and didn't work. I'll prolly send mine in again once I figure out if it will work with the intake I'm getting.
before
after
before
after
yea. make sure you use the correct tb. The sensors work with the ecu (also dependent on tranny) and using the wrong one causes poor throttle response. I mean a few mm porting should not cause any hp loss. Normally, you should gain at most 5whp arcoss the power band.
Originally Posted by Michalo187
hahahahah go for it man if you got good it would be a good way to make some money i wonder how hard it could be
haha, ill see what tools i can find for my dremel.
Bruce2
Sep 27, 2015 08:45 PM
Bricoleur
Sep 9, 2015 12:30 PM
... ust dont mess it up like i did.. take the sensors out
