HID fuse
Old May 26, 2005
HondaLuver's Avatar
Its a celebration bitches!
HID fuse
i just recently got and put D2 hid's in my car and it was blowing my stock headlight fuses. the 15's and i put 20's in there and it blew those also, a few people are like, dont' put anything higher than whats rated because i might fry the wires, so right now its hooked up to a switch and its hard wired... so my question is that, what fuse to use... the ballist says it uses 85w... what fuse do u guys think i should use?
Old May 26, 2005
gh0st's Avatar
TAQUITOS!!!!
85W ballast?...most i've ever heard of is 50W...and the projector ballasts that's commonly used is 35W.
perhaps you can have someone make you a harness to handle the power from the stock plug to the harness to the ballast plugs?...
or handle the power from the battery to the switch and ballast (which is what i'm assuming you have?)
Old May 26, 2005
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
yeah you should get a wiring harness made for them. contact OcelarisO3 on aim he made a harness for me when i had my retrofit. he does good work and is very helpfull
Old May 26, 2005
dirtySAMURAI's Avatar
I log in from time to time
i also vouch for ocelaris. he's a local to me and we met up once. very informative guy and he made my harness lickity split.
as for your problem, hondaluver, do what everyone else is telling you to do: don't use a higher amp fuse because wires can only hold so much current before melting. the OE manufacturer rates the wires at 15 amps before something might happen, so stick with 15 amps. now that you know this, get a wiring harness made for you. make sure the harness has at least 16 gauge wiring.
Old May 27, 2005
HondaLuver's Avatar
well they are from a acura TL type S, the hids are very bright. i think they are 6300k, but they are pure white, no other random colors. i'll contact him soon then, let me just finish putting these casper HID turkey basters on and see the diffrent these sheilds make.
Old May 27, 2005
any car manufacturer will use 4100k, unless it's bmw. they have an option for "color-matched" bulbs which are 5000k.
Old May 31, 2005
HondaLuver's Avatar
yea it was 35 w, it was 85 volts, im a dork
Old May 31, 2005
HondaLuver's Avatar
and yea i searched, and it looks like they are 4100, i put the sheilds on, they point straight, i need to adjust them so they look down now...lol
Old Jun 9, 2005
gimme dat's Avatar
gimme dat is an unknown quantity at this point
i had the same prob. w/ my fuses keep bein blown...... CHECK ur connections.. make sure none of the wires are touching w/ the others.. i cleaned up my connections n never had the problem since
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
TheRiddicles
Sep 21, 2015 01:28 AM
h4ldol
Sep 17, 2015 01:25 PM
