Nasty Odor From A/C?
Everytime i start up the A/C there is a weird nasty odor coiming from the a/c. its not only when it starts, everonce in a while it will come back. does anyone know what it could be
2004 EX Sedan, 35k
Thanks
2004 EX Sedan, 35k
Thanks
I just talked to one of my boys, he has an older civic, he said he had the same problem and that it was freon that was leaking? Does freon smell funky? i will probably take it to the dealer
Back From The Banned!
how many miles do you have? As zen master said, check the cabin filter behind the glove box. When I checked mine at 25K miles, there was a lots of pollen, some dead bugs, leaves, dirt,.... it was black. haha
It's not the cabin filters. Mildew forms in the system when you use the a/c alot and keep it on recirculate mode. Use fresh air mode instead and even leave the fan **** open instead of closed/off when you shut off the car. For now, run the heater full blast for 5-10 mins to get rid of the mildew.
Most likely the mildew is building up in the evap drain that runs to the bottom of the car. That is where alot of condensation builds up. What you can do is go under the car and check to see if that drain is plugged or you can do a system cleaning with wynns AC cleaner, or however its called.
press the little button that uses outside air for a little. Sometimes its good to use the ac with outside air. That should get rid of the smell.
i doubt it....
i've been trying to do that from a long time ago..
HOWEVER...one should probably realize that it never happened during winter.....that's when we use the heater all the time....LOL...
so...there's gotta be something with the AC....
not the freon....but the compressor or the tubes which colden the air......
or probably the vent....even though i doubt that....because, if it's about the vent, then it should be smelly EVERYTIME i use the AC..
however, it comes now-and-then......not regularly...
how much do the new cabin filters run? and where do i pull it out?
i've got my car in for service and they want to charge me $90 to change it and there's no way i'm shelling out that kind of cash for something so simple.
what gear box said, just use the air from outside and not the recirculating air. My car has 50,000 miles on it and the only time i've ever have that problem is when im stuck behind and old car with all the smog coming from it. I close my vents so it recirculates the air. when i forget to open them up after i park, come back turn on the A/C and it smells. so leave ur recirculating air button off if u dont like it smelly.
h4ldol
Apr 24, 2017 08:16 PM
JMKendrick
Sep 16, 2015 06:17 PM
MichaelLW
Sep 14, 2015 07:15 AM
Mannimarco
Sep 7, 2015 10:01 PM
