HELP on HID kit
HELP on HID kit
i just got a Catz HID kit, 4300k......but anyone know how to install this kit...any DIY HID out there..pls post link....it come with manual, but all japanese...
i want to install it on OEM housing....any help tks,
Originally Posted by ImPulse
Where did you get the HID kit? Catz has stopped making kits for over a year... o_O
Help......pls check if i connect all the wires correctly......cuz i install one side first but
bulb doesnt light up....do i have to install both side then test that?
THis is Catz H4, low beam only...
Connection looks right.
I have a Bellof kit which is the same has a Catz.
If it isn't lighting up, check the fuse which is the black box next to the bulb.
If that's not the case, you might need new bulbs.
still not working.... i checked the fuse and bulb...
for the ground wire...i connect this to anywhere on frame of car and one side connect to the negative terminal right?......also it come with one extra 15A fuse, do i needed to switch the stock fuse to the 15A? 2 others fuses install on HID kit...
Help, pls
thanks,
Help, pls
thanks,
If the fuses don't blow, then you don't need to switch them out.
Heres how to test the bulb:
1.First disconnect the red wire where I circled it.
2.Take that red wire coming out of the bulb and connect it to the positive (+) side of the battery.
3. Take the ground wire and touch the negative (-) side of the battery.
4. The bulbs should light up and work.
You can leave the bulbs in the plastic case when you do it.
If this fail on both bulbs and ballasts / ignitors...
You either have 2 f'ed up bulbs or ballasts/ignitors or a combination of both.
Immediately contact the person you bought it from and ask for a refund.
thanks, LikeaFerio....
i just tested the HID...both workin fine...
but when i connect that PGS 3pins on OEM stock bulb connector and run that (black) ground wire to the chassie (and run passenger side ground wire to the negative - terminal.....two side of HID bulbs doesn't light up at all.....u know whats problem i have now?...tks,
Try testing but don't connect the black ground wire and see if it works.
The 3 prongs on the H4 plug is for
1. postive low beam
2. postive high beam
3. negative ground
I'm a little confused myself as to why the adapter has all 3 plugs available but Catz makes you put in another ground wire.
What I would so is trash the PGS adaptor.
Chrimp a connector (the one that looks like the 3 prongs) to the end of the red wire and stick that into the postive low beam on the cars headlight plug.
Wire the ground and it should work without the need for the adapter.
You can buy the connector at any hardware store.
1. postive low beam
3. negative ground
i have the same kit, but with hi/low controler. Do you have the sheet that shows the connections? It's all japanese, but all you need are the pics to show where the connectors go. Lemme know if you need this and I can take a pic.
i have the manual instruction, but not understand that...cuz all japanese.
did you connect any wire to your positive terminal?....cuz i connect that 3pins harness to the stock OEM bulb connector to get that power from battery...and run the ground wire on frame chassie, and negative terminal.....
is your HID kit come with that PGS 3pins adapter?
tks for ur reply, appreciated if you can help out.
ya yours won't have that rectangle box in the middle. I remember plugging a connector to one stock headlight plug and leaving the other one disconnected. One wire connects to battery positive, all the rest goto chassis grounds.
1. postive low beam
3. negative ground
1. postive low beam
3. negative ground
the 3 "prongs" on the H4 plug is actually:
1. low ground
2. high ground
3. +12v
is it waterproof?....if it is anywhere away from heat and close enough for the connections to reach...such as the fenderwell...or bumper support. also depends on what you're going to use to hold it up
i put mine next to the battery under the stock intake tube, and the other one driver side around the headlight back. There's a little shelf if you reach between there.
HELP ......
oky here's problem i have now...how can i put back that stock rubber waterproof thing back to headlight....cuz Catz HID have one extra red postive line from the inside..... all the wires can't poke through the stock rubbur mount......cuz fuse and pulg in the way........pls help asap....i'm in middle of installation.
Hey I just cut mine from the middle to one side. Thats the only way, and it still doesn't fit back perfectly. There's just too much stuff to stick through.
