Cam/Spark Timing questions
is there any other way to adjust spark timing ive always wanted to go this, i was thinking about buying those coil pakcs but there so expensive, do the stupid piggyback ecus like venom and jet dont adjust that do they ? can emanage or aem ems change rev limit aswell? what else can ?
Originally Posted by djmota
no.
spark timing is done by the ecu. it is only adjustable with emanage and ignition harness or aem ems.
it may affect a lil bit but probably nothing that would either be predictable,noticable, or beneficial. I believe our stock ECU uses both the cam and crank sensor to determine optimal ignition advance. I may be wrong on this though. I dont ever have to worry because Im running my cam straight up and running an ems lol. I know It may seem like our ignition systems suck but believe me they work SOOOOO much better than coil/distributor ignitions. Between that and the iridiums that come in our cars, once you have some adjustablity you dont need anything else.
cam gear..
..have succesfully installed and run AEM cam gears on 03-05 Civics here, and yes, ignition timing changes by itself, in relation to the advance or retard of the cam gear. Anyone else tried this and got results?
yehni got a cam gear advanced 3 degrees with stock cam it made a big difference in low end power but i lsot like 5mph off the top speed before i would go 135mph now i can only go 130 but it was worth it i got alot more torque, i dont know anything about the ignition timing though
Turbos, Engines, Chassis and Suspension Tech
Ignition timing is run off of the cam angle sensor which is also referenced against the crank angle sensor which tells the ECU exactly where the motor is at any point in time. The cam angle sensor determines which cylinder fires and and what time.
Definitely..
Originally Posted by gearbox
a cam gear should always be tuned on a dyno.
..but for some ppl, dyno isn't an option, so just lending my experience.
are you sure about that argus, when you retard it supposed to give you more horsepower and less low end toque, or when you got boost, you get more topspeed aswell when you retard but less low end power which is what i want thats why i advanced it
sure man..
Originally Posted by DaddyFatSacks
Dyno is the only option, unless you wanna advance or retard to much and loose power, thats up to you! $125 bucks to loose power, i'd get it tuned.
dosmastr
May 5, 2015 12:19 PM
Grazzhopper
Nov 11, 2001 08:06 AM
