Engine Shampoo Question
Old May 8, 2005
Cyberkinetic's Avatar
Cyberkinetic is an unknown quantity at this point
I want to clean the engine bay in my 01 civic with one of those engine degreasers, however, I'm a little worried about spraying down my engine. I have heard of people's engine lights coming on after shampooing their engine. Are there any parts that I should avoid getting wet? Can anyone give me a little advice on how to do it correctly?
Thanks
Old May 8, 2005
KYjerry414's Avatar
KYjerry414 is an unknown quantity at this point
cover up the valve cover.
Old May 8, 2005
KYjerry414's Avatar
i'll send u a link for the DIY engine cleaning.
Old May 9, 2005
streetglower's Avatar
you dont need to cover the valve cover.
When I cleaned my engine bay, the only thing I covered were the opening of the intake and the tranny dipstick because of how flimsy it sits in the tranny. then I sprayed away. But make sure you dont spray directly at the alternator. And dont spray hard at any parts, lightly spray everything. You will be fine.
Old May 9, 2005
Old May 9, 2005
robbclark1's Avatar
Retired suspension supermod.
spray with simple green, spray off with light mist. YOu don't need to cover anything if you give it a few hours to dry. So if you want to do it, do it at like 5pm on a Monday, and just leave your car out to dry over night.
Old May 9, 2005
2K1Civic17"Gabe's Avatar
I windex my engine bay, rofl!!! haha, I really do to.
Works like a charm. But Its more of a maintaining the clean engine, than cleaning it first with it. If it gets really nasty, I would just use soap/water, and let everything dry. I just dont spray near the intake filter. and I try to keep it away from certain spots (electrical). Just dont spray directly on electrical, and when you dry it up, just move the towel over the spots you missed, cuz the towel will be wet anyways, and will clean it up. Mag polish is a good thing on the engine after you clean it as well. Made my engine shine nicely.
Old May 10, 2005
Thanks for all your advice. If anyone comes across a formal diy guide, I still wouldn't mind taking a look.
Old May 11, 2005
robbclark1's Avatar
you can also steam clean it.
Old May 11, 2005
Titleist71's Avatar
Blue Coral make an awesome cleaner. It is safe on all clearcoats, paints, unfinished aluminum, pvc plastic and many other things. Its the Wheel Cleaner. I use it on my STi. Make sure the engine is cool, cover alt. with plastic bag, cover intake filter too if u have one. Spray cleaner, let it soak for like 2-5 mins.....and rinse again. It works amazingly well. Give it a try for $4. why not.
Old May 12, 2005
southpasdena's Avatar
Super Member
southpasdena is an unknown quantity at this point
where is the alternator?, thought u were also supposed to cover the distributor cap and everything, i dont spend much time under the hood, maybe i should spend a little more
Old May 12, 2005
robbclark1's Avatar
Maybe you should because on the 7thgen there is no distributor cap.
Alternator is right in the front. You can't miss it.
Old May 12, 2005
Flashlightboy's Avatar
Flashlightboy is an unknown quantity at this point
Simple Green undiluted if really dirty. Diluted 50% if just dusty. Rinse with light mist. Cover the filter unless it's stock.
Old May 12, 2005
Super Member
thanks, kinda guessed there was no distributor, but just wanted to make sure, same with the alternator, i know what they look like but i mess things up alot so no harm in checkin
Old May 12, 2005
ncirom2003's Avatar
i just drove into the DIY car wash bay at the local place and poped the hood and had at it, didnt cover anything didnt watch fore certain areas, i sprayed every square inch and had no problems. then i went to home depot and they had a engine degrese spray, (oddly it was near doorknobs and handles) and the spray was 5 bucks it worked pretty good but id say it only has 2-4 uses in the can depending on you.
Old May 12, 2005
ncirom2003's Avatar
and to know which is the alternator, its got the openings around it near the front and you can see wires that look like they are wrapped around something, sometimes they are a color.
thana
Jun 15, 2020 07:05 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
zack22490
Apr 29, 2015 03:17 PM
supercivic01
South
Nov 30, 2001 11:27 AM
Grazzhopper
Nov 11, 2001 08:06 AM
