Anyone know how to reset the ABS indicator light?
Old May 7, 2005
luke02civic's Avatar
luke02civic is an unknown quantity at this point
Any one know how to reset the ABS indicator light? I recently took the sensor off to do some work and put it back on but the light still is on i just need to rest it...the owners manual doesnt tell u how to reset it.
Old May 7, 2005
Philip's Avatar
Philip is an unknown quantity at this point
drive like 30 minutes contineously and it will reset on its own
Old May 8, 2005
fink's Avatar
fink is an unknown quantity at this point
Do a search on the topic. You can find a step by step method
Old May 8, 2005
MegaHurtz's Avatar
Moved to Tech Stuff
Old May 10, 2005
High_OctaneZ's Avatar
High_OctaneZ is an unknown quantity at this point
The ABS light goes off when you fix the problem. you do not reset it. if it is on there is something wrong with abs and it is deactivated. fix the prob and the light will go out immedatly.
Old May 10, 2005
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
take it to honda and have them look at it, if nothing is wrong then they will reset it... thats if its under warranty. if not disconnect the battery or pull the fuse for the abs sensor.
injen
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
Blazz
May 25, 2015 10:56 PM
jimmyfloyd
May 20, 2015 07:06 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
injencivic
Nov 9, 2007 02:31 PM
