Q for XTEC HID owners!
4 cyllinders are good but 5 is better!
I assume its for H4? If it is then you shouldn't even have the option to turn on the high beam. It should already be disabled unless they started making em differently. You should just get nothing when you flick your highbeams cuz there is no filament for the high beam.
it's not that there is no high beam, it's just that there is no wire for the high beam ground wire to go to...the high beam. you have a low beam and when you flip on your "high beams," what GreatWhite02 said will happen (get nothing)
Originally Posted by Boggie1688
What if you have the 9006 connectors? Does that change anything? or still no high beams?
brags
Oct 2, 2015 05:53 AM
Hutch1051
Sep 29, 2015 09:20 AM
