Grinding Noise
Old May 5, 2005
GoNeIn60
Guest
Posts: n/a
Grinding Noise
Whenever im in 2nd gear and i rev to 4-5000 rpms and go to shift into 3rd quickly I feel a small gear like spinning and it makes a grinding noise. I made sure that i had the clutch all the way down and it still did it. Its only when its that high in the rpms is when it grinds. Lower than 4 and it has no problem at all. Also when im in 4-5 rpms and i hold the clutch in for 2-3 sec then its able to handle it without any grinding. Any ideas on what it could be or is that just how its suppose to be? Thanks guys
Old May 5, 2005
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
I'm pretty sure it's not suppose to do that...bump
Old May 5, 2005
GoNeIn60
Guest
Posts: n/a
my friends told me that it might be my syncro's but i dunno if they are right or not
Old May 5, 2005
That would be my guess, the gears arn't lining up correctly, but I don't have much experience with the em2 trannys...read this
http://www.7thgencivic.com/forums/sh...=209350&page=2
and maybe try PMing 'cg95660' or 'sdcivic549' they seem to know what they are talking about...
Kind of reminds me of, sometimes, when I go to back up and throw it in reverse, even if I double clutch, it grinds...
Old May 6, 2005
mclean987's Avatar
mclean987 is an unknown quantity at this point
i have the same problem the synchros are on there way out , this is the 2nd time i already rebuilt tranny and changed the synchros, my car does that too but only after ive been driving for like 4- hours or if im racing, anyway you need to change the oil to a thicker oila dn it will help right nopw im using gear oil which is like 75-90 instead of the 10-30 were supposed to use and it stop grinding, you can also use lucas oil or add some moly
Old May 6, 2005
Jrfish007's Avatar
Yeah basically what he said. I had that same problem in an older civic I had, but I drove the car almost 50,000 mile like that and it got a little worse with time. But I just babied the 2-3 shift when I wasn't racing or something and never had any real problems. Later if I was shifting hard I might miss the 2-3 gear, I hope it's because of that, but it was probably just becuase I suck at shifting
Old May 6, 2005
GoNeIn60
Guest
Posts: n/a
Ill try the heavier wieght oil hopefully that should do it, what are good types that you guys would recommend? BTW thanks goes out to Thefivespeeder for puttin this thread into a tech thread for extra help.
Old May 6, 2005
Jrfish007's Avatar
Redline oil is good IMO
Old May 6, 2005
GoNeIn60
Guest
Posts: n/a
ok cool
Old May 6, 2005
2K1Civic17"Gabe's Avatar
Put it in first,than reverse and it will never grind on ya. My friend told me that a few months ago, cuz he hear my reverse grind a few times. It has worked everytime, not once hae I grinded in reverse. and i gots almost a 100,000 on my car/clutch/transmission.
Old May 7, 2005
04civicdx's Avatar
04civicdx is an unknown quantity at this point
my tranny just started that tonight and i have a 04
nirvanaguy
25
Oct 26, 2017 07:26 PM
siliconvalley
Sep 15, 2015 09:48 PM
junkyardguy
20
Sep 6, 2015 10:07 PM
tooly145
Sep 5, 2015 01:05 AM
JJ291
Sep 2, 2015 11:49 PM
