Front Sway Bar
yes it will fall on you decapitate you and youll lose use of your dong, then your going to turn green from shoulders down and your car will roll off the ramps and down hills with you caught onto front bumper.
or if your lucky nothing will happen <---- im betting for option B
just be sure you chok the tires and e-brake it, good luck
jack stands would probably be better, although i doubt the car will move.
do put on ebrake and wedge some 2 by 4's behind all four tires if you are going to do it on the ramp.
Autocross Junky
Originally Posted by Kubias
I have my car up on ramps right now will anyting happen if i change the sway bar while up on the ramps??? Like fall on me??
PC Tech / Autocrosser
I installed my front sway bar while my car was on ramps. No problems. It's just a trick to put the bar in place without an extra set of hands and w/o having to drop the exhaust. Hope you're good at puzzles.
I just installed an EX lower sway on my 01 LX, now i am hearing a popping noise everytime i turn and a small vibration/rattle coming from the lower right wheel area.....what coudl be wrong? Loose? if so shoudl i jack the car up to tighten it down or leave it on the ground(under load)
mrohitredd
Jun 9, 2015 06:37 AM
Rogelio Rey
May 24, 2015 08:30 PM
Dorval Andre
May 1, 2015 09:37 AM
