Finally Dynoed the beast*Dyno sheet pics*
Well I just got back from a local dyno day and I think I did all right under the circumstances. I need to go back and pull some fuel as Im running pretty rich. But I ended up with 193.15HP and 174.13TQ at 8 psi. My fuel ratio was running around at 9:1 and 10:1 so I know once I pull some fuel that I could get close to the 200 mark at 8psi. I still have alchy injection to come too. So I hope for 215 @psi next month.
Originally Posted by C2i0v0i1C
not a good AF though
Originally Posted by HyaBoosta
has anyone hit the 200 mark at 8 psi?
well seeing as how I ripped one of my o2 sensors out and the other is zip tied up I should be ok.lol besides replacement sensors go for 38.00. I don't know who charged you that much. check hondaautmotiveparts
7thgen Power Maker
make sure to leave it a lil rich to be safe. Take temp and humidity into consideration. The effects are drastic. If you tune your car perfect in 80 degree weather when its 60 and you do a highway run you will run sooooo lean. It effects things a lot more than most people realize.
Munzy
21
Oct 7, 2015 07:48 AM
Touge
Sep 23, 2015 11:19 PM
