turn signals not worken after Injen RD installed..
Old Apr 11, 2005
blkvic's Avatar
blkvic is an unknown quantity at this point
I just switched intakes from AEM sri to Injen Rd..and once i installed the Injen RD i noticed my right turn signal would flicker on and off...i put in a new flasher but that only made if worse and now both turn signals dont even work..Iv'e read on the forums that the ground wire needed to be switched around to get a better connection and i did that but no succes in my turn signals worken..Anybody have any suggestions on what i may need to do to get em back worken??
Old Apr 11, 2005
goodtimes's Avatar
i think you need to ground it or something like that b/c when i put mine in i hade the same problem.
Old Apr 11, 2005
streetglower's Avatar
when you put the cold air on, right where the filter sits, there is a ground connection that is used that connects to the intake. You need to check that connection. I guarentee you that is where your problem is.
Old Apr 11, 2005
civicvtec1ps's Avatar
Search and Learn
Yup, that's it.
Just check the ground on that spot.
Old Apr 11, 2005
blkvic's Avatar
thats what i did..i changed the screws to that padded medal screw to bolt the intake in place(screw that came with intake).could that be the problem for them not to be working and possibly getten a bad ground?
Old Apr 21, 2005
2K1Civic17"Gabe's Avatar
check fuses
edit - Do you touch the glass when you install new bulbs? If so, that probably cuased the new one to stop working, and maybe the other one was time to be replaced. You should replace both bulbs when one side goes out, so they will die close to the same time (go longer w/out installing another bulb).
Check your fuses though!
Peace
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
steveneddy
May 19, 2015 02:39 PM
shaejb15
Apr 26, 2015 07:44 PM
Fastfebur
Apr 22, 2015 01:37 PM
blackbullet
Dec 1, 2001 03:44 PM
