Lookin for the DIY black housings headlignts!!!
Old Apr 9, 2005
VinhTEC's Avatar
VinhTEC is an unknown quantity at this point
Angry Lookin for the DIY black housings headlignts!!!
Lookin for the DIY black housings headlignts!!! I need the link if anyone has it i want to paint my headlights cuse i am low budget : )
Old Apr 9, 2005
vtecd17's Avatar
Desperate Custom Swapper Speed Freak
vtecd17 is an unknown quantity at this point
DIY section, check out CLEARING HEADLIGHTS DIY. Its all you need to get your headlights apart, then just pain from there on. No biggie.
In a nutshell, remove your bumper, get your lights off.
Bake your lights in the oven at 325 F for bout 2 mins. Pry the housing apart with a screw driver. Get the housing itself apart from the clear plastic.
Primer, paint the plastic to desired color, let dry.
Push headlights together, (silicone if you wish) re-bake them, same temp, same time. Pull them out of the oven, push them together REAL tight. Add more silicone, DONE!
Took me bout 4 hours full work to mine.
Old Jul 8, 2005
NPROOT's Avatar
NPROOT is an unknown quantity at this point
Exclamation Me TOO!
Yes please post pictures and a step by step DIY for blacking out headlights for thoes of you that have already susceded. Thank You for your help
Old Jul 8, 2005
cg95660's Avatar
Wanna see a donkey show?
cg95660 is an unknown quantity at this point
You do not need to bake them. ANd yes the diy for clearing them is all I used. I used krylon fusion and 400 grit sand paper. You just have to tape off what you do not want black. I then used 3m window sealant. Its just like the stuff in there already. Note be careful when putting the newly painted peice in, I had to wet sand about three times before getting it right. Also you just have to pull straight up on the peice to get it in and out.
Old Jul 8, 2005
importuner86's Avatar
importuner86 is an unknown quantity at this point
Just did this yesterday with my brother for his S14. Bake them, pull them apart, paint them, put them back together. It's pretty easy.
Old Jul 8, 2005
gh0st's Avatar
TAQUITOS!!!!
it's in the lighting forum.
jessicanicole
Jul 23, 2015 09:14 AM
Smokahontas123
Jul 22, 2015 10:07 PM
Kyles24
Jul 16, 2015 10:14 PM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
BootyDo
Jul 7, 2015 06:06 AM
