ground control coilovers w/ stock shocks good or bad?
Old Apr 7, 2005
tommyhoang_ta's Avatar
tommyhoang_ta is an unknown quantity at this point
hi guys, i am thinking about to get that set up (ground control coilovers w/ stock shocks). Has anybody got that set up before? How the ride quality? how long will it last? I wanna lower around 2.5-3 inches all around. Need advices from u guys, thanks.
Old Apr 7, 2005
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
yeah you'll blow the shocks if you go that low.
Old Apr 7, 2005
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
Your stock shocks will not last very long and I've read that the Ground Controls dont ride very well... especially at that low of a height.
Old Apr 7, 2005
what should i go for that low? how about this http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WD1V
Old Apr 7, 2005
tfnaaf's Avatar
BLDNPSI Mod
I dont understand why people say that lowering a car will cause the struts to go bad. Its not the lowering that causes it. Its the the PI$$ poor quality struts they put on cars stock!
Old Apr 7, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
And you know whats really pathetic about it is that Showa makes the stock shocks. And their aftermarket available shocks are very good.
Anyways, I don't understand whats up with the "GC ride sucks". It seems fine to me.
1. Don't expect a progressive ride out of straight rate springs.
2. Don't expect a stock ride out of something 3 times as stiff.
They don't ride any different than any other coilovers I've experienced
Old Apr 7, 2005
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
it wont be THAT bad, but eventually (depends on driving habits and conditions), your stock shocks will wear away resulting in shitty ride quality.
as for being GCs, im sure its just like any other sleeve coilover. i rode on skunk2s for the first few months and it was ok... but months later, ride was getting shittier. and i was on 195/60/15 tires which isnt low pro at all.
if you still go with GCs, keep in mind they have 2 different sets. one meant for stock shocks and one meant for koni yellows. check out www.importhorizon.com
btw, dont go with skunk2...had problems such as clanking noise on the fronts, adjusting the coils on the perch is difficult, and GC > Skunk2 as for sleeved coilovers.
Old Apr 7, 2005
Zzyzx's Avatar
Autocross Junky
Well... If you get them, start saving for some shocks now.
If your trying to make the car handle better, Your better off starting with dampers (shocks) 1st and springs 2nd... Simply because the car is under dampered from the factory and if you throw a set of springs on there that Triple the spring rate... You end up with a car that is SEVERLY under dampered.
Old Apr 7, 2005
P.O.S.B.A.S.04's Avatar
Ever Wonder What P.O.S.B.A.S. Is An Acronym For
P.O.S.B.A.S.04 will become famous soon enoughP.O.S.B.A.S.04 will become famous soon enough
you will have a bumpy a$$ ride if you stick coilovers on your stock shocks and they will go out hella fast. i do not know why but the rear seem to go first. i think you would rather go with springs that drop it 2"
Old Apr 7, 2005
civic21's Avatar
civic21 is an unknown quantity at this point
so just coilovers on stock suspension=new shocks in about say 3 months or so?
Old Apr 14, 2005
yeah, stock shocks on our cars blow. and they blow very quickly
Old May 2, 2005
Krumz's Avatar
Krumz is an unknown quantity at this point
i have ground controls on my 04 lx but only had them for a week or so now but the ride isnt as bumpy and well i know they will blow pretty soon but the drop makes up for the ride
Old May 3, 2005
wicked_civic_2k's Avatar
wicked_civic_2k is an unknown quantity at this point
GC coilovers
I had a set with my factory shocks for a year before the rear went out. But then again i also had them all the way down including modifying purch to allow for more adjustments.I never had a problem with them being bumpy though. The thing i didn't like was because they make a sleeve for the factory and 1 for the aftermarket,you can't change your mind later and but aftermarket shocks and expect them to work on the factory GC coilover sleeve. You have to buy the whole new set.
Old May 4, 2005
philsep36's Avatar
philsep36 is an unknown quantity at this point
i have ground control coilovers with the stock strut and have driven on for about 2 years and i am just startin to need some new struts. it wont get bad in such a short time. so lower now and you could hold out for new struts. i am just now startin to look for struts myself
Old May 4, 2005
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
what is a safe drop with coilovers and stock shocks? 1"-1.5" or less??
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
GolNat
Nov 27, 2018 03:32 PM
Munzy
21
Oct 7, 2015 07:48 AM
Tedverseti
Sep 29, 2015 05:41 PM
hondacivic0253
Sep 29, 2015 08:06 AM
