SRS Light - Didn't Unplug Anything To Set It Off
Old Apr 5, 2005
ackos's Avatar
ackos is an unknown quantity at this point
Hello,
My SRS light is currently on. After doing some research online (forums), I found the instructions on how to reset the light. The problem I have is that everytime I reset it, it does go off, but comes back on within a few minutes. I've checked both seats and the harness is secure. Does anyone know all of the areas that would trip the SRS light and cause it to come on? Also, my horn will sometimes work and sometimes not (I bet that's it huh?).
If there is a list of areas in the Civic that I could check to make sure. There may be something unplugged that I dont know about.
ackos
Thanks in advance.
Old Apr 5, 2005
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
fuse maybe??? I dunno if its that intermitent might be a more serious problem. Take it to Honda and let them look at it.
Old Apr 6, 2005
streetglower's Avatar
Originally Posted by ackos
Hello,
ackos
Thanks in advance.
It is just like having a check engine light, you have a problem in the SRS system. Either buy a scanner designed to check SRS codes, or take it to the dealer.
Old Apr 6, 2005
Al Gore FTW's Avatar
jdmtytedoridori
yeh, i was gonna say the same thing. my uncles isuzu something a while back had that happening and he took it in. it wasn't anything big just some sensors or something.
Old Apr 6, 2005
P64's Avatar
P64
P64 is an unknown quantity at this point
If it comes on, then it is suppose to come on. Don't play with your life. Take it to your dealer.
It seems to me, that the problem is with the steering wheel, since you have problems with your horn. There are some connections that allow you to operate your horn and the airbag independent of your steering wheel position.
A
Old Apr 8, 2005
2k2civic's Avatar
How many miles on the car? Some cars will throw a light after a set number of miles because they need to be taken in for maintenance.
jimmyfloyd
May 20, 2015 07:06 PM
cukaracha
May 16, 2015 02:11 PM
bo_red
Transmission
May 3, 2015 09:14 PM
dragonsblood
Apr 27, 2015 12:28 PM
SimDogg
Nov 27, 2001 04:20 PM
